Another oil question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2wdTRD, Aug 2, 2014.
  1. Aug 2, 2014 at 6:52 PM
    2wdTRD
    2wdTRD [OP] Well-Known Member
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    I just had my 3rd "free" Toyota care oil change today and noticed on my invoice they put in 0w-20 and the past two were 5w-30. Now from searching on here I see the 4cyl. uses 0-20 and my V6 should get 5w-30. My question is, should I go back and get it changed to 5w-30 or is the 0w-20 ok for the next 5,000 miles?
    Judging from this info it looks like I should get it changed to 5w-30. http://rav4world.com/pdf/T-TT-0005-10.pdf
    Thanks for the help.
  2. Aug 2, 2014 at 7:14 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Personally i would switch to 5-30. 0-20 is thin. My wifes acura uses it, and its like water. One time when I was changing the Acura's oil for the first time I spilled oil all over the engine cover because of how easily it flowed out of the jug. It surprised me. It flowed way more easily than 5-30.
  3. Aug 2, 2014 at 8:11 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah.... this is why you wont catch me in the dealer getting my oil change done. go back, and have them change it and the filter.... make sure you mark the filter to make sure they change it.... hell ask to stand by your truck while they do it to make sure.
    As you can see i trust them about as far as i can throw my truck..... Not when the head service mechanic couldnt get the right tool for the driveline tsb, so i provided my tools, then couldnt read the tsb that the truck had to be at ride height... then ordered the wrong parts.... all the while i caught the oil change boy just about to start my truck with no oil in it.
    5k miles was the first and last time my truck will be there for oil changes.
  4. Aug 2, 2014 at 8:26 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I have no input with the type of oil but... That damn fly in your sig got me
  5. Aug 2, 2014 at 8:51 PM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    Ok the bug you have crawling around just messed me up with the iPad, the signature area. Haha. Especially since I just drank a lot.
  6. Aug 2, 2014 at 8:55 PM
    MagnumTaco
    Tony
    New Mexico
    Ok, get it changed to the correct. I use Royal Purple so I provide my own and watch them do it. It might feel awkward but your truck is worth it.
  7. Aug 2, 2014 at 9:06 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    That's why I've always done it myself since day one. Peace of mind to know that's it's always done right with the oil of my choice
  8. Aug 3, 2014 at 6:04 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Well ... now that we're on the oil change subject (sorry to jack the post) ... this is my first V-6 after 30 years of 4 bangers ... I absolutely LOVE the filter location.
    That little drain hole at "6 o'clock" is for dripping oil I suspect ... where does it drain to?
  9. Aug 3, 2014 at 6:11 AM
    moondeath
    Pa, Gardners
    You need to put a catch container under it. Otherwise it will drain into the engine bay.
  10. Aug 3, 2014 at 6:17 AM
    bowhun2r
    bowhun2r Well-Known Member
    Scott
    Steeler Nation
    19 - GX-460
    Get yourself some 3/8" inside diameter clear vinyl tubing. Search for this on Amazon: "Watts SVIG20 Pre-Cut 1/2-Inch Diameter by 3/8-Inch Clear Vinyl Tubing, 20-Foot Length". Or go to your local auto store.
    That will fit nicely on the nipple. Take off the plug, put a few feet of tubing on it. Route it down onto the ground and place the other end into an empty beer bottle. When you crack loose the oil filter it will drain down the tube into the bottle. You should be able to replace the filter w/o having a drop of oil hit your engine bay or ground. Once it's drained, replace filter...replace the nipple until next oil change.
    I'd buy a beer for the Toyota engineer who thought of this design.
  11. Aug 3, 2014 at 6:31 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    X2 damn bug couldn't get it off the screen, and I haven't been drinking:eek: lol
    Have them change it back!
    The drain is for changing the filter. It drains to whatever is beneath it. So put something there! I use GOOP hand cleaner container, so I have a lid I can snap on before snaking it out:thumbsup:
  12. Aug 3, 2014 at 6:39 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Thanks for the answers ... I was thinking the engineers didn't make it that simple.
  13. Aug 3, 2014 at 6:49 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    The tacoma pre runner is the easiest oil change to do yourself!
    You don't even have to jack the truck up. I wont let anybody work on my toys.
    Have someone show you how to do it so you know its done rite every time.
    And yes 5w-30 is what you want to run
  14. Aug 3, 2014 at 8:24 AM
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    Thanks for all the input, I do know how to change my own oil and in the past I always have. I may just swap it out myself and specify at the next one, it took them over 2hrs to get me done yesterday and I don't have patience for that again. By the way a tire balance in $56.00 WTF?? I continue to use them because I have the 2 year Toyota care, as soon as it's gone I will be doing the services myself at my job. Only thing I really want to keep track of is all the records for the B.S. lifetime warranty it has, I work with them all the time at my job and have some decline a transmission repair because they missed an engine oil change!!
    Oh and that bug's name is Mark because that's what he leave on your screen. :D
  15. Aug 3, 2014 at 8:31 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    unless it's a long way away, you "paid" for an oil change, you deserve to have the correct oil put in. You shouldn't have to pay for another oil change. If you do change your own oil, at least call the stealership and speak with the shop foreman or heck, even the GM or owner about what the "mechanics" are doing.
  16. Aug 3, 2014 at 9:02 AM
    bowhun2r
    Scott
    Steeler Nation
    19 - GX-460
    My experience with the free 2 year maintenance...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/190651-24-month-maintenance-plan-new-tacos.html
    I have an extended 7/100K bumper to bumper (purchased it online for half the cost of what they were going to sell it to me. And it is a Toyota backed warranty. Got it I think somewhere in the midwest where they sell them online jerryj@MidwestSuperstore.com. It's a Toyota dealer and they sell factory backed warranties all over the US).
    Anyways back to my point, the oil change is a breeze on our trucks and as many people have experienced issues at the dealership (as I did) I just do it myself. I keep all the receipts and have a log book of milage and dates of when I do any type of maintenance.
  17. Aug 3, 2014 at 10:33 AM
    nd4spdbh
    SoCal
    there is a reason why i spent 45 bucks for 10 OEM filters and drain plug washers so i never have to have the dealer do it again.
  18. Aug 3, 2014 at 2:21 PM
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    Damn I just read your issues there, that sucks. I went out today before traveling to Mobile and checked my oil, to me it looks thick. I know what 0w-20 looks like on the end of a stick, its like water. This was thinner than a honey consistency but still appears thicker than the 0w-20. I'm still going back to get them to do it again but I think maybe the service writer wrote down the wrong weight.
  19. Aug 3, 2014 at 2:53 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
  20. Aug 3, 2014 at 3:00 PM
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    I don't beat on the motor and I am aware its a very good synthetic, the wrong oil (in this case being thin) will not cause instant issues but a long term problem so damage under warranty will most likely not happen. I just don't know the specs of this motor, if it's not going to hurt anything then I really don't mind but if this thin oil does not lubricate to what the motor needs then I'll get it redone.
