Another OME Lift ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sporty_Taco, Apr 15, 2011.
  1. Apr 15, 2011 at 8:51 PM
    Sporty_Taco
    Sporty_Taco [OP] Member
    2010 Tacoma Sports
    Ome 885 w/ 2" AAL, LR UCA.
    Planning on lifting my 2010 tacoma dcsb 4x4 (non-tsb). I've been doing research on this site a lot but seem not to find my answer. Just want to know if the OLD MAN EMU LIFT SUPSPENSION with the 885 coils with a 2" AAL will level out my truck or will the tsb 1.5 AAL level it out? Also, I will not be adding the top plate spacers. I don't haul anything but just want my truck level and do some hunting and fishing. THanks.
  2. Apr 15, 2011 at 9:16 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    The TSB AAL will help somewhat, but probably not enough with the 885s up front.
    Get the TSB done, then get the AAL for the TSB rear leafs from OME, that is what I did.
  3. Apr 15, 2011 at 11:40 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    subd im interested to because im planning on doing the OME setup later on too
  4. Apr 19, 2011 at 8:45 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    Bump
    Kind of wondering this myself. I have a 2010 4WD Sport DCLB, and I've bought the 885 with OME shocks for the front (no spacers). Now I'm considering what to buy for the AAL from ToyTec (for non-TSB leafs) to achieve more of a level look. Based on my measurements, my truck sits 1.75" higher stock. So if I get 3" out of the 885s (without spacers), as some people say you can, the 2" AAL will result in 0.75" of rake. However, if I use the 1.5" AAL, I'll be 0.25" higher in the back. Not sure how the measurements will even out after settling though. Any input would be appreciated
  5. Apr 19, 2011 at 8:49 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have an 09 DCLB 4x4 , I just installed the 885's without the spacers today , I got 2 3/4" up front , I also have the Dakars out back as I haul and will be getting a cap soon .
  6. Apr 19, 2011 at 8:54 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Sub'd... Good looking truck OZ-T.
  7. Apr 19, 2011 at 9:46 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    sub. from the info ive gather over the past few months, it seems with an AC the 885s are giving about 3'' up front (without the spacer), and a 2" AAL is causing the truck to sit dead level (without a cap). as for DC (and 4x4), id say you'll get a little under the 3'' in the front. assuming you dont have a cap or anything, maybe skip the TSB and go with the 1.5" AAL in the back? :notsure: seems like most of the DCs (stock) are riding about 1.5" higher in the back than the front...that'd give you about a .25" rake, which should look level.
    just my .02
  8. Apr 19, 2011 at 10:01 PM
    OZ-T
    Peter North
    British Columbia
    Thanks
  9. Apr 19, 2011 at 10:10 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Is it bad to go with the top plate spacer on top of the 885's?
  10. Apr 19, 2011 at 11:14 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    i wouldnt say bad, they are made to work with the spacers. but it seems most are getting the 3" (or close to it) without the spacers, and are okay with sacrificing the .25" or so for a better ride.
  11. Apr 19, 2011 at 11:29 PM
    StandingCow
    NJ
    I went with the spacer and my ride is fine..
  12. Apr 19, 2011 at 11:31 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    i havent run either setup, im just going with what ive read. im sure the ride is alright with spacers, as it is a package made to be used together, though spacers usually= a reduction in ride quality.
    food for thought :notsure:
  13. Apr 20, 2011 at 4:07 AM
    JonnyBb
    Arkansas
    Thanks for the numbers OZ-T. Glad to see you finally got it installed. Not stalking you, just saw in another thread that you had the kit sitting around for a while. I actually bought the same OME kit as you, but a buddy of mine bought my dakars to go with his icon coilovers.
  14. Apr 20, 2011 at 4:21 AM
    JonnyBb
    Arkansas
    I don't know enough to make my opinion worth $0.02, but that's kind of what I was thinking. I'm not totally sure if the rear or front is going to settle more in the long run though. I don't haul anything regularly, so the leafs shouldn't sag anytime soon.
    A buddy of mine suggested that I install the front without the spacer, install the 1.5 aal, and then take a look at how it sits. If it turns out to be too high in the front, I could then swap out the 1.5 aal for a 2. Swapping the aal is easier and cheaper (no alignment) than installing a spacer.
  15. Apr 20, 2011 at 11:52 AM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    thats a good call. if you go with the wrong leaf, im sure you could install the new one and sell the old on here for like 50-60$, so you'd only be out maybe 20$ and 45mins of work.
  16. Apr 20, 2011 at 5:07 PM
    JonnyBb
    Arkansas
    thanks hNs....actually i wound up going in a little different direction. my buddy and dan for wheelers sold me on a set of the 1.5" 3-leaf progressive AAL. i just placed the order.
    just fyi, i talked to toytec this afternoon and for a level look, they recommended the 1.5" AAL for at DC LB with non-tsb leafs, 885 coils, and OME shocks.
  17. Apr 20, 2011 at 8:58 PM
    Sporty_Taco
    2010 Tacoma Sports
    Thanks for all the inputs. Will try the 1.5 AAL and see how it is first.
  18. Apr 21, 2011 at 11:23 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    How much lift did you end up getting with the spacer?
  19. Apr 22, 2011 at 12:42 AM
    StandingCow
    NJ
    Dunno, I didn't measure... probably around 3 inches after settling. I have had this setup for about a year now, and my CV boots haven't ripped or anything, no grinding...
