Another P0110 code thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by TNutz, Jul 26, 2025 at 3:59 PM.
  1. Jul 26, 2025 at 3:59 PM
    TNutz
    TNutz [OP] Member
    Hello 1st gen family. I'm trying to check the AIT sensor wires on my '95 2.7 truck for bad connections. Looking/need a wiring diagram. Y-B and B-Blk wires. Replaced sensor with new in box sensor, same symptoms. Rough idle, misfiring stupid.
    I replaced the aftermarket distributor that came in the truck with a factory Denso dizzy a couple weeks ago and the truck had been running great.... until it wasn't.... again. Please send help to this thread, I'm about to drop kick this &**&^%%$&** !! :annoyed::annoyed:
  2. Jul 26, 2025 at 4:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Best I got until someone can find me a connector pinout for the IAT sensor plug.
    Also see the attached file.
    TNutz[OP] likes this.
  3. Jul 26, 2025 at 5:15 PM
    TNutz
    TNutz [OP] Member
    Thank you Shooter. I looked again it is Y-G, not Y-B. Probably saw Y-G wire then immediately thought blue lol!!
    The PDF is cut off on the right hand side of the file, I'm not versed well enough on these test procedures. Meaning; I can't make the connection in my old brain so I can do the continuity test at the harness, or ECM terminals without all the text showing up for me. BUT, that file is EXACTLY what I was asking for brother! Only if I could read the rest of it. :thumbsup:
  4. Jul 26, 2025 at 5:25 PM
    TnShooter
    Deogee
    STOCK
    Try this
  5. Jul 26, 2025 at 5:27 PM
    TnShooter
    Deogee
    STOCK
    FWIW, you can do a continuity check from the Brown/Black on the Throttle Position Sensor to the Brown/Black on the IAT sensor.
  6. Jul 26, 2025 at 5:28 PM
    TnShooter
    Deogee
    STOCK
    If you can't open a PDF file, let me know.
    I can try to screen capture and post a direct picture here.
    (But TW compresses the files for some reason, and makes them a bit blurry at times)
  7. Jul 26, 2025 at 5:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have a scan tool that can view live data?
    If so circuit integrity can be verified very easily.
    TNutz[OP] and TnShooter like this.
  8. Jul 26, 2025 at 5:32 PM
    TnShooter
    Deogee
    STOCK
    Indeed it would.
    The data for the scan tool was in the file I posted in post 2.
    I think OP might be hiving a hard time opening PDFs.
  9. Jul 26, 2025 at 5:33 PM
    TnShooter
    Deogee
    STOCK
    OP if you have a scan tool, look at live data of the IAT.
  10. Jul 26, 2025 at 6:13 PM
    TNutz
    TNutz [OP] Member
    I'm able to open them, it was that one file was cut off.
    My son has the live data scanner, I'm still with a code reader at this point in the game. He's hard headeder than I'm is... he must be teasing me, or just won't let dad use it!! Boy, I say BOY! Bring me that scanner@!
  11. Jul 26, 2025 at 6:18 PM
    TNutz
    TNutz [OP] Member
    Heck yeah! I'm asking my son to bring the scanner.
    Dude! I like that "don't be a parts changer" video!! That's my philosophy to a Tee. Thanks for the reply.
    Dm93[QUOTED] likes this.
  12. Jul 26, 2025 at 6:20 PM
    TNutz
    TNutz [OP] Member
    Will do, probably tomorrow. I just had to diagnose my '89 SR5 that wasn't starting when you posted that. Let it sit for a few months this time. Had to jump fuel pump terminals at the test block, fired right up.
    TnShooter[QUOTED] likes this.
