Another p0430 (bank 2) 05 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomajeff, May 18, 2011.
  1. Sep 26, 2017 at 11:25 AM
    #61
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Something like this :cool:
  2. Sep 26, 2017 at 11:26 AM
    #62
    Obiwade
    Obiwade Member
    2010 TRD Off-Road
    I really appreciate it!
    I was actually just reading the PDF!
  3. Sep 28, 2017 at 7:43 PM
    #63
    Obiwade
    Obiwade Member
    2010 TRD Off-Road
    Just thought I’d update here with what I’m doing.
    I ran some Seafoam through the vaccum line to check for an exhaust leak. Didn’t see anything obvious.
    Picked up some 18mm spark plug non-foulers and used them on the rear bank 2 cat.
    So we’ll see if the light comes back on in a day or so. Planning to test fuel pressure this weekend.
  4. Sep 28, 2017 at 7:54 PM
    #64
    Sandman614
    Tim
    '06 SR5 Off Road
    The anti fouls will just mask a problem, not fix it. A lean condition can do some damage if not fixed.
  5. Apr 9, 2018 at 8:18 AM
    #65
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    I used the anti foulers and no more check engine light ! Cats are probably shot thou
  6. Apr 9, 2018 at 8:19 AM
    #66
    Sandman614
    Tim
    '06 SR5 Off Road
    Hiding the problem instead of diagnosing it. While it might "work" for you.. It's not a good solution.
  7. Apr 9, 2018 at 9:17 AM
    #67
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I had a P0420 code. Using an obd2 reader and torque app, i saw the O2 sensor was all over the place. I found a bad donut gasket at the Y pipe and replaced both... Solved.
    Try swapping O2 sensors for side to side and see if the code changes. Mine didn't, so i knew it wasn't the O2 sensor.
    Sandman614 likes this.
  8. Apr 9, 2018 at 9:46 AM
    #68
    Sandman614
    Tim
    '06 SR5 Off Road
    Bingo!
  9. Apr 9, 2018 at 11:11 AM
    #69
    Larzzzz
    Larry
    MA
    You could try some stuff called cataclean. It's not cheap, but compared to the cat, it's a drop in the bucket.
  10. Feb 18, 2019 at 3:16 PM
    #70
    greenhoffa
    greenhoffa New Member
    So my 2006 tacoma with 150,000 CEL just threw the p0430 code . Truck seems to run fine .. I plan on fixing but Wondering how long I could drive it before it starts having issues. Like the cat getting too clogged ? Is it something that needs to be addressed right away ? Don’t wanna get stranded
  11. Feb 18, 2019 at 5:15 PM
    #71
    joes06tacoma
    Joe
    Central Coast, CA
    I've been driving with mine for 3 years and around 20K miles. No symptoms other than the light. Recently had the exhaust off and was able to look in from below, looks fine. I'll probably get it done later this year, but my mechanic says there isn't any hurry as long as it runs good and there's not rattle coming from the cat, which would mean the honeycomb material is falling apart.
