Another Positive Dealer Experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mark C., Jan 20, 2010.
  1. Jan 20, 2010 at 2:28 PM
    Mark C.
    Mark C. [OP] If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Another Positive Rear Spring Experience
    Just got my 2010 2WD A/C, 4-banger back from the dealer. Got the 5K mile maintenance done and........the Harsh Ride TSB done.....
    They went beyond the 2nd rev to the TSB, which called for replacing only the rear springs and not frame/body bumpers or any shocks....here's what I got:
    1. Replaced 3-leaf springs with 4-leaf springs (48210-04570 and 04210)
    2. U-Bolt (90117-A0005) (X4)
    3. Spring Bumbers (48341-04080) (X2)
    4. Shock Set (48510-09U50) (X2)
    5. Shock Set (48530-09Q40) (X2)
    6. Complete 4 wheel alignment.
    I had also mentioned the reduced air flow output when the heat selection was all the way up (high)....they didn't change the damper out as prescribed in the TSB, because I didn't mention the TSB....just complained about air-flow. Well they replaced the blower motor and blower sub-assembly. I will take the TSB for the Heat/HVAC with me for the 10K mile visit and see what they do.
    Dealership is in Old Saybrook, CT....Lorensen Toyota. And......the loaner I got was a 2009 Taco A/C, 4.0 Automatic.
    Guess what was on the floor? You got it! Tacoma all-weather floor mats...and they never moved the two days I drove it. I asked about getting some, but....told they couldn't sell them...........
    They also washed and vacuumed my truck.....and...........
    Another thing............I DID NOT buy my truck from them!
  2. Jan 20, 2010 at 2:39 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    awesome dealership
  3. Jan 20, 2010 at 4:05 PM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    09 Tacoma
    I thought the harsh ride TSB was for 4WD only? That is what dealer told me. I thought I read the TSB was changed to make it apply ONLY to 6 cylinder?
    More info?
  4. Jan 20, 2010 at 4:08 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    Got mine done no questions asked...:cheers:
  5. Jan 20, 2010 at 4:21 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Hmmm... wonder if there's a thread about good and bad dealerships. If not, someone should start a list.
  6. Jan 20, 2010 at 4:27 PM
    chmura
    chmura Well-Known Member
    So the 2010's are part of the leaf spring TSB?? I thought this was a 2009 TSB? Wouldn't Toyota put the new part numbers on 2010's??
  7. Jan 20, 2010 at 4:29 PM
    tcBob
    Bob
    get the updated tsb pdf here...now has 2010s
  8. Feb 1, 2010 at 4:35 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Sorry....my typing sux! I have a 4X4.....and yes ....it applies only to 4X4's ....engine size does not matter.
  9. Feb 1, 2010 at 5:26 AM
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    Nope. 2WD and 4WD.
    Double cabs and Access cabs only.
    VDS(s): JU4GN, JU62N, KU4HN, KU72N, LU42N, LU4EN, MU4FN, MU52N, TU4GN, TU62N, TX4GN, TX62N, UU42N, UU4EN, UX42N, UX4EN
  10. Feb 1, 2010 at 5:48 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    I stand connected...........er.........uh corrected! Thanks Monrad!
