another prerunner ---> 4x4 conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by josh843, Nov 12, 2015.
  1. Nov 12, 2015 at 4:43 PM
    josh843
    josh843 [OP] Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    i know there are a ton of these threads between here and toher boards, however i havent seen anyone do a reg cab conversion and was wondering what if anything is different. i know about the 4x4 trans, trans case, front diff and axles and all that. but is there anything different like the ecu or anything. found a trans and transfer csae for 300 bucks on craigspace but its for the 3.0
    Also mine is a 2001 reg cab prerunner automatic, with crusie. i would like to retain this feature and dont really care about ADD or manual hubs either way. which ever one is easier, from what ive read the hubs are the way to go and everything is more or less bolt in basicaly. but like i said, havent seen someone with my setup do it. thanks.
  2. Nov 13, 2015 at 4:06 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Uhm, your sig says 2010 and you are inquiring about a 2001... which is it? That will be good info towards answering your questions.
  3. Nov 13, 2015 at 4:10 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    he's got a 1963 chevy mustang.
  4. Nov 13, 2015 at 4:29 PM
    josh843
    Josh
    moncks corner, sc
    2001 sold the '10
  5. Nov 13, 2015 at 4:31 PM
    josh843
    Josh
    moncks corner, sc
    lol nope but i do have a 04 ford lighting, built with 630 rwhp on street tune. close to about 800 rwhp if anyones in the market...
  6. Nov 13, 2015 at 5:45 PM
    josh843
    Josh
    moncks corner, sc
    anyone? just need to know if i get a wrecked parts truck (01-04 reg cab auto 4x4) can i just swap main components over?
  7. Nov 13, 2015 at 6:50 PM
    Kyle N
    Kyle N Active Member
    Don't buy anything from a 3.0 truck, wrong side transfer case drop. If you bought a wrecked parts tacoma everything will swap. If you find a transfer case with manual hi/lo/4wd (AKA J-shifter) you won't have to worry about electrical. If you get a electric t case you will have some wiring to fuck with. Or harness swap, which is a big task. Any Tacoma auto 4wd trans from 95-04 will work. The 00 and prior are more likely to have the desired t case (j shifter).
  8. Nov 14, 2015 at 4:08 AM
    Ritchie
    OP...
    I am doing exactly what your planning, only difference is the SAS.
    I have a Diamond axle and 3 link kit awaiting install.
    For the trans/ T case, I have an A340F and Inch Worm case. No electric crap whatsoever.
    Check out Scuba's build in the solid axle section.
    Good luck.
  9. Nov 14, 2015 at 11:33 AM
    josh843
    Josh
    moncks corner, sc
    Yea I figured nothing from the 3.0s would work. Wad just say I g there was a he'll of a deal on one. So ANY 95-04 4x4 trans will bolt up? 4 cylinder or 6 cylinder? Or just the 4 cyl?
    And definitely want a "j" t case. Not trying to do any wiring on a 14 yr old truck.
  10. Nov 14, 2015 at 11:36 AM
    josh843
    Josh
    moncks corner, sc
    Thanks ill check it out
  11. Nov 14, 2015 at 6:32 PM
    Kyle N
    The bellhousings are different but you already got that on your current trans. Any auto and tcase 4wd from a Tacoma will work. 4Runner stuff will too but there are a lot electric cases and center diff models.
    And you shouldnt pay more than about 500 for a trans+tcase total. These things arent exactly 'desirable.' They just work well and are all over the place. You should be able to find a tacoma tcase for well under 300.
    I believe the tcase has to be from a auto trans vehicle. I think the bolt patterns are different. But someone correct me if I am wrong.
    I did a 4wd swap in my 99 V6 Prerunner back in 07. Used a 00 4runner auto with a electric tcase. I wired the tcase first try and worked. Always did unless the power lead fell off my radio amp inside the cab which is annoying. I have to admit I am glad I am going back to a manual shifter.
  12. Nov 15, 2015 at 11:59 AM
    josh843
    Josh
    moncks corner, sc
    yea, i recently sold a '01 4runner with the ADD and center diff lock, it was nice to have to not get out and lock it in and all that, but it was not as simple as just moving the "j" t case and being in 4WD and thats it. sometimes the ADD or diff would stick ...
  13. Nov 15, 2015 at 12:11 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Hi @josh843, there is a Tacoma World and TTORA regular @Ritchie, he has a killer 2003 single cab auto pre-runner he converted to 4wd with a solid front axle. It's one of the best builds I've ever seen. He would have tons of good info for you. Here are some photos of his truck:
    http://www.justacarguy.blogspot.com/search/label/Mike's truck part 2
  14. Nov 15, 2015 at 7:06 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The only hitch is that the trans has to match the engine type of the tcase. 23 spline for the v6 and 26 for the 4 cylinder. You could always mix and match couplers depending on what you get with each too.
  15. Nov 15, 2015 at 7:16 PM
    Kyle N
    My recommendation, dont do what they were saying. Its a waste of time and money. You dont need to build a geared case, the chain cases are fine and bolt on. If you want a 4wd truck just find a stock tacoma j-shifter.
    josh843[OP] likes this.
  16. Nov 16, 2015 at 6:22 AM
    josh843
    Josh
    moncks corner, sc
    Yea I'm not trying to go SAS. I just got a real good deal on this truck and want 4WD. O don't really "wheel" but I've been in plenty of situations where I needed 4WD and after seeing how easy it is to swap with these trucks its deg worth it for me to buy a parts trucks rather than sell this one and buy a 4WD truck.
  17. Jan 18, 2016 at 10:31 AM
    josh843
    Josh
    moncks corner, sc
    ok guys, been tied up, the lightning went to shit on me and ive been busy getting it back on road and then sold it, so now i can concentrate on this project full time. are there any website, besides flebay that i can source all i need for the swap? have to look back into what all i need, forgot since ive had my mind in other places with the L. im looking to buy all the parts and and then make the swap on a weekend. as this is my only truck now. well thanks and ill keep updated. good to be back! missed not showin the taco any attention.
  18. Jan 18, 2016 at 10:38 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The auto and manual t case are interchangable...has to be from a v6 3.4...
    -j shift t case
    -tranny
    -diff
    -cv and spindles
  19. Jan 18, 2016 at 10:39 AM
    anthony250f
    Anthony
    San Diego, CA
    Do a j shift and manual hubs
    Zero wiring
  20. Jan 18, 2016 at 11:07 AM
    josh843
    Josh
    moncks corner, sc
    thanks +1
    def the route i want to go, thanks
