Another problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Sep 15, 2019.
  1. Sep 15, 2019 at 6:06 AM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello I have notice that my truck when it goes over 50 mph it gets a shaky feeling and starts to slightly go to the sides
  2. Sep 15, 2019 at 6:08 AM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    Ties rods worn out and/or alignment needed/tire balancing?
  3. Sep 15, 2019 at 6:45 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    O okay ima checks those out thanks
  4. Sep 15, 2019 at 6:57 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    How many miles?
  5. Sep 15, 2019 at 6:59 AM
    1997tacomav6
    Denver
    Typically this is from worn out shocks and or struts or worn tires or balance.
    If it’s coming from the seat could be the driveshaft issues.
  6. Sep 16, 2019 at 12:34 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    143500
  7. Sep 16, 2019 at 4:55 AM
    CS_AR
    Check both.
  8. Sep 16, 2019 at 11:44 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Several messages ahead of this one is a link to a video showing how to check the lower ball joints. You might want to check that out too.
