Another question from new owner Claudine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Claudine, Oct 6, 2021.
  1. Oct 6, 2021 at 10:25 AM
    Claudine
    Claudine [OP] Member
    2005 Tacoma
    Hello! I've already gotten so much help here (thank you!) that I thought I'd ask my latest question:
    Engine just clicks when I turn the key, but the emergency clutch start gets her going right away. Battery connections are solid. Any ideas? I note she revs a bit when I first start her up.
    Thanks!
  2. Oct 6, 2021 at 11:26 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If it won't start when you step on the clutch but starts with the clutch cancel switch it sounds like a bad clutch pedal switch.
    claudine19 and D2. like this.
  3. Oct 6, 2021 at 11:39 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I would agree.
    do you have Cruise Control?
    If you do i'm guessing it wont work due to a possible faulty clutch cancel switch.
    not too expensive, and anyone who's comfy on turning a wrench should be alble to swap it out. Be warned, its tucked up in there and may require you to contort your body! ( I know I had to!! )
    claudine19 likes this.
  4. Oct 6, 2021 at 11:49 AM
    SWOR_taco42
    SWOR_taco42 Active Member
    Ian
    2015 Tacoma
    do you mean push starting and popping the clutch?
  5. Oct 6, 2021 at 12:57 PM
    D2.
    Dan
    Nova Scotia, Canada
    I believe she's referring to the clutch cancel start switch.
  6. Oct 6, 2021 at 1:00 PM
    claudine19
    claudine19 Member
    Hi Everyone,
    No cruise control here --- former owner was a back to basics kind of guy. Or at least if I do have it, I sure don't know where it is!
    Didn't push until started; stumbled upon the clutch cancel switch as a helper in desperate circumstances. But I'll look into the clutch pedal switch.
    Thanks! As always, you've all been very helpful. I appreciate it.
  7. Oct 6, 2021 at 1:11 PM
    TacoTuesday1
    SD CA
  8. Oct 6, 2021 at 4:20 PM
    Waasheem
    Waasheem
    2007 xrunner
    I hated having to stomp the clutch to start. So I did the delete mod, simple as removing the relay and sticking in a wire with a couple spade connectors on it. I had the same symptom, occasionally it would just click and not start. I tested the clutch switch, it was bad, thats when I bypassed it. After that, it would still occasionally just click, but not as often. As recommended by Jimmyh, I replaced the starter solenoid contacts. After that it starts every time I turn the key.
    If you decide to bypass the clutch switch, it's important to remember if anyone else ever drives it, assume they left it in gear. Valet parker, car wash, mechanic, etc. So you don't turn the key and have it take off into something.
