another question
Discussion in 'Suspension' started by RIDDICK3, Aug 21, 2012.
  1. Aug 21, 2012 at 12:52 AM
    RIDDICK3
    RIDDICK3 [OP] nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    my shocks are going bad but i dont have the money to buy everything for the lift I want. now I have a 2.5 inch spacer kit up front and the shocks im going to get are bilstein 5100 can I set these at zero to have the same ride height? or would that damage the shock?
  2. Aug 21, 2012 at 1:01 AM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    you'll be fine just make sure they wont bottom out, usually you'll hear it if its bottoming out but i dont think that would be a problem
  3. Aug 21, 2012 at 1:04 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    If you put your stock coils on Billies set at 2.5" you would have about the same ride height you have with the 2.5" spacers. Then later you could replace the stock coils with Eibach or OME coils & set the Billies to 0" or .85" max.
  4. Aug 21, 2012 at 1:24 AM
    RIDDICK3
    Stefan
    Orem, Utah
    You think the ride would be a little better if I just set the billies 2.5 and took the spacers off
  5. Aug 21, 2012 at 6:00 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    With the billies at zero and the spacers on there, the ride would be about the same as with the billies at 2.5 and no spacers. It's just redundant to have the spacers on there because the 5100's preload the spring themselves.
  6. Aug 21, 2012 at 10:18 AM
    RIDDICK3
    Stefan
    Orem, Utah
    aight thanks for the info guys
