Another recall screw up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Cid, Apr 15, 2014.
  1. Apr 15, 2014 at 1:12 PM
    El Cid
    El Cid [OP] Well-Known Member
    South Carolina
    11 Access Cab, 4 cyl, man., SR5
    I waited to take my '11 Tacoma Access Cab in for the seat belt recall in hopes they would develop some expertise.
    Called today for an appointment. Had to make one to take it in and they keep it for an hour to see "if it needs the work." Then they will order the parts, which are already backordered for others. Asked about waiting until they had parts in stock and service advisor said I had to bring it in before they would order the parts.
    This really sucks!:mad:
  2. Apr 15, 2014 at 1:13 PM
    anotherreject
    anotherreject Well-Known Member
    Well that sounds retarded
  3. Apr 15, 2014 at 4:48 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Didn't they send you a letter for the recall? That is a mandatory recall they don't need to look at your truck.
  4. Apr 15, 2014 at 7:28 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Depends on whether the screws came loose yet or not IIRC. They didn't have to replace anything but the screws on mine. If the tensioners are already rattling around in the door they're supposed to replace the whole mess, and that's what's potentially backordered.
    It should explain it better on the recall notice
  5. Apr 16, 2014 at 9:14 AM
    El Cid
    South Carolina
    Notice says 1.5 hours to do the repair, which (IMO) should include replacing the pre-tensioners if required.
    Says dealer will inspect system and replace all four screws. If all four screws are lose at time of inspection, will replace seat belt pre-tensioner. Nothing about ordering them first.
    Don't think much of them having to remove and replace the panels twice for what should be a one time job.
  6. Apr 16, 2014 at 9:17 AM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    It only takes them about half a hour. They replaced all mine. Now I have to take my door panels off to tighten the bolts because the idiots who changed it out didn't. It rattles over every tiny bump.
  7. Apr 16, 2014 at 9:21 AM
    bigbarlo
    bigbarlo The Church of @ODNAREM OC Chapter 80085
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    I made an appointment with a local dealership. They said over the phone it should take them an hour or so. Took four hours.
  8. Apr 16, 2014 at 9:46 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Your truck probably sat for three hours?
    Mine was done in one hour. But I left it with them for the day. They called me fast to tell me to come and get it.
