Another Satellite Radio Question
Discussion in 'Audio & Video' started by JustAGuy, Nov 28, 2012.
  1. Nov 28, 2012 at 5:23 AM
    JustAGuy
    JustAGuy [OP] Member
    Base
    Hello. I am new to the forum. I just bought a new 2012 regular cab base Tacoma. I pulled my aftermarket Sirius system out of my other car and want to install it in the Tacoma. I don't want to buy a new head unit right now, so I plan on using the satellite receiver I had velcroed into my other car and old magnetic antenna. From my searching on the web, I don't think my old antenna will drive the factory stereo. If that isn't true, please speak up.
    My problem is that I don't know how to get the satellite wire into the cab of the truck. Does anybody know how to get wire into the cab? I have searched around the forum and figured out that I need to tuck it into the seal around the windshield and take it into the engine compartment, but I don't know where to go from there. Any ideas?
  2. Nov 28, 2012 at 5:37 AM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    When I used aftermarket sat radio, I put the antenna near the roof channel on the rear passenger side of the roof. I ran the wire down the channel, under the rear window seal, then down the back of the cab to the underside of the truck. I then zip tied it to the frame rail and ran it to under the front passenger seat area and thru the rubber grommet there. You will then need to remove the trim piece, just pull straight up, and reach under the carpet and under the seat to grab the wire.
  3. Nov 28, 2012 at 9:49 AM
    JustAGuy
    Base
    How did you secure the wire running down the back of the cab between the rear window seal and the underside of the truck?
  4. Nov 28, 2012 at 9:54 AM
    sirwillysc
    sirwillysc Well-Known Member
    Will
    Columbia SC
    13 Tacoma Dbl Cab TRD Off Road
    Debadged destickered
    You could do what I did and ditch the whole thing. i signed up for a internet only subscription through XM and downloaded the app to my phone now all I do is bluetooth it. Just an idea, i know it kinda sounds like alot spelled out but its really simple
  5. Nov 28, 2012 at 11:55 AM
    JustAGuy
    Base
    I am one of the lucky few that don't carry a cell phone, so that idea won't work for me.:D
  6. Nov 28, 2012 at 12:10 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    I just used a plastic spackle spreader or anything similar that won't scratch the paint and lifted the edge of the window seal and ran the wire under it. Once it's under the seal and at the bottom, you won't really see it anymore. From under the truck I pulled it tight and zip tied it to keep it secure. So from the bottom of the rear window seal to the underside of the cab, it's not physically secured. But with the zip tie keeping tension on it under the truck and the pressure from the window seal, it isn't going anywhere.
    If you don't want to do it that way, a lot of people remove the third brake light and run the wire into the cab that way. You will just have to tuck it under some panels, possibly remove some as well, to run it to the front of the cab.
  7. Nov 28, 2012 at 8:00 PM
    JustAGuy
    Base
    Has anyone had any success mounting the antenna on the dash? I have heard about doing it that way, but it sounds like a bad idea to me.
  8. Dec 2, 2012 at 3:15 AM
    JustAGuy
    Base
    I got it installed yesterday using parboy's original suggestion. It was a pretty easy install.
    Thanks parboy.
  9. Dec 2, 2012 at 3:25 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    No problem! Glad you got it done!
