Another Seized LCA fiasco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedoJosh, Jun 26, 2017.
  1. Jun 26, 2017 at 1:51 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So, I did some searching, and am seeing a lot of people with the same issue. Seized LCA bolts. Common problem, no real "fix" besides replacing. My question is, has anyone used the Moog LCA replacements from Rock Auto, and if so, how are they holding up? Did they come with everything?
    Thanks
    -Josh
  2. Jun 26, 2017 at 2:23 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    There's a whole thread on the Moogs someplace. I recall people ended up having frequent problems with them. Go with OEM and just coat everything with anti-seize is I think the current TW advice (what I did as well). Be sure to coat all the sleeves with anti-seize - it isn't really the threads so much that are the problem but the sleeves/bushings themselves seizing.
  3. Jun 26, 2017 at 3:42 PM
    SpeedoJosh
    Florida
    Saw that. From what I gathered seemed to be more of a problem with people putting Moog bushings in OEM LCAs. Not much I could find on issues with Moog LCA assemblies themselves.
    If I get another LCA, no matter what brand, what's the alignment assembly called? The whole caster/camber set up called? I assume I'll need that too.
