another set of Fox or Kings to replace these rusted, broke trd pro ones
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bludweiaer, May 24, 2020.
  1. May 25, 2020 at 6:16 AM
    bludweiaer
    bludweiaer [OP] Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    im considering kings also, they are alittle cheaper, are they 0-3 in lift also ?
    JKU3000 likes this.
  2. May 25, 2020 at 6:17 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yes they are
    JKU3000 likes this.
  3. May 25, 2020 at 6:56 AM
    sweeneyp
    sweeneyp Well-Known Member
    Patrick
    2019 Toyota Tacoma TRD Offroad, 1994 FZJ80
    JKU3000 likes this.
  4. May 25, 2020 at 7:08 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Kings will rust too:
    https://www.tacomaworld.com/threads/broken-king-coilover-spring.654792/page-3#post-22888055
    https://www.tacomaworld.com/threads/broken-king-coilover-spring.654792/page-2#post-22812589
    All the coilovers require judicious washing and touchup with a thin rust preventative spray (Fluid Film, Krown, etc.) several times each winter. The fine machined threads and metal-on-metal contact are just high maintenance.
    JKU3000, AKGSD and whatstcp like this.
  5. May 25, 2020 at 7:26 AM
    angerbot
    angerbot Well-Known Member
    OP, you might consider Elka as well. They use aluminum for everything (shock body, shafts, adjusters) and from what I've seen on trucks up here in Alberta they hold up the best to road salt. I have limited seat time with them but I was impressed enough to order a set for myself.
    JKU3000 likes this.
  6. May 25, 2020 at 10:06 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Doesn’t toyota have a 5 year corrosion perforation warranty? Especially since this is a safety issue, you could probably get them to fix it
  7. May 25, 2020 at 10:13 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Lol.
    Who?
  8. May 25, 2020 at 10:17 AM
    angerbot
  9. May 25, 2020 at 10:23 AM
    eurowner
    eurowner Duke Sky
    Scoty
    All good, but the coil springs are still steel.
  10. May 25, 2020 at 10:30 AM
    angerbot
    That's true - tbh I've never seen a coil spring rust out like that photo in OP. OEM or otherwise.
    Maybe they need some of those neoprene shock covers.
  11. May 25, 2020 at 10:53 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I grew up in the seacoast of NH and my family mechanic would have a pile of snapped and sagged OEM front and rear coil springs of different makes, due to rust. I have lived in Colorado for 21 years now and still hear of it happening.
    Those body covers are excellent catching and holding particulate matter, salts, and moisture against the body, causing more damage.
    JKU3000 likes this.
  12. May 25, 2020 at 11:32 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    eurowner[QUOTED] likes this.
  13. May 25, 2020 at 12:12 PM
    bludweiaer
    pa
    ive had 3 other taco's, and none have rusted like this one, this was going to be my 10 yr. truck, not sure now..
  14. May 25, 2020 at 2:49 PM
    stun gun
    Aaronski
    Tacomas.
    5nahalf likes this.
  15. May 25, 2020 at 8:06 PM
    #35
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    According to the warranty booklet, the corrosion perforation warranty applies to "any original body panel". Suspension components would just be covered under the 3-yr/36k basic warranty. Depending on when @bludweiaer got his truck, that may have expired. Anyway, looks like @bludweiaer wants to lift and upgrade, not just return to the status quo.
    AKGSD[QUOTED] likes this.
  16. May 26, 2020 at 4:39 AM
    #36
    bludweiaer
    pa
    yes warrenty is out on that stuff, gonna get a set of fox resi's, 0-3 lift, and a set of icon UCA's, got a 1in. block in rear, that will be coming out down the road, and replace rear leaf pac.
  17. May 26, 2020 at 5:05 AM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Icon UCAs? Going with Delta Joints?
  18. May 26, 2020 at 5:14 AM
    #38
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    The OEM trd pro coils have a known issue where they break right on the first loop. They lack a taper in the cut like most coils have which causes a stress point.
    For OP: you really can't go wrong, I personally run ADS, most people run Kings, some run Fox, some run Icons.
  19. May 26, 2020 at 5:53 AM
    #39
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  20. May 26, 2020 at 6:01 AM
    #40
    bludweiaer
    pa
    yes gonna order later today, found the fox's 50 bucks cheaper, than where i was going to order from, going to see if they price match. cant believe the caps are separate to buy,,
