Another steering wheel shaking thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caduceus, Jan 11, 2011.
  1. Jan 11, 2011 at 1:25 PM
    Caduceus
    Caduceus [OP] Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    I just got back my 09 DC from getting the 15K mile service, as well as getting the new TPMS calibrated to my truck (FJ wheels on BFG ATs). Going in to the shop the truck ran well - stock up front suspension, the TSB AAL and a 1.5" AAL in back.
    Now, coming out, the truck rides well still. But starting at about 50mph, the steering wheel shakes. Not constantly. Like, a second on, and a second off. When shaking the steering wheel can be visibly seen to vibrate about 1/2 inch. Then it settles. Then starts. Then settles. It's not similar to a flat or out of balance tire (which were fine going in). The truck doesn't drift or really behave any differently. No funky sounds.
    I'm taking it in on Saturday for them to fix whatever the jacked up. I'm pretty sure that, due to the intermittent nature, it's not the alignment or balance.
    Ideas?
  2. Jan 11, 2011 at 1:33 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Sounds to me like the wheels need to be re-balanced...might be missing a weight.
  3. Jan 11, 2011 at 2:01 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Except, at 60mph, that wheel is spinning so fast that the wobble would be constant.
  4. Jan 11, 2011 at 4:36 PM
    OffroadToy
    4X4 Offroad
    Have you checked the lug nuts?
  5. Jan 11, 2011 at 5:41 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Uh, nope. I guess I can do that.
    Tire pressure 34 PSI in all four (cold pressure)
  6. Jan 16, 2011 at 1:23 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Problem solved. Apparently the rear wheels were OK in the rear, but up front were out of whack.
    So, apparently I'm mistaken about having an intermittent whobble with wheels. Who knew?
  7. Jan 16, 2011 at 3:54 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    So what was out of whack with the front? Balance?
