Another Stereo Upgrade Thread
Discussion in 'Audio & Video' started by ryneati, Apr 5, 2018.
  1. Apr 5, 2018 at 11:19 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I got the NVX 0/1 AWG Power Wiring kit - 20' of 0 AWG Power OFC, 3' of 0/1 AWG Ground OFC, 9-10' of 4 AWG power and ground OFC for distribution to the amps, two power/ground distribution blocks, and 1 fuse holder and 1 fuse - all that for $130 from Sonic Electrix. The same Kicker power wire kit at the time was $200 or more - as far as I could tell, it was the same as the NVX kit. That's about as cheap as power wire will get before buying stuff sold on Amazon and ebay - then putting your own kit together.
    NVX x-series RCA noise rejecting cables were purchased separately. No issues at all when it comes to power or signal.
    ryneati[OP] likes this.
  2. Apr 5, 2018 at 11:40 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Not a bad price for 0/1. If you're going over 1500w RMS, I'd fo sure go that route. I'm a fan of the Kicker wiring myself. The PK4 kit runs $99 at best buy, but they will price match walmart for $65 if you ask.
    Man of Steel TRD likes this.
  3. Apr 5, 2018 at 11:42 AM
    ryneati
    ryneati [OP] Well-Known Member
    Ryne
    Raleigh, NC
    Would this bitch work or at least be a good start? I'm trying to track down all that you mentioned there but thought I would ask haha
    https://www.sonicelectronix.com/item_38906_Stinger-SK6641.html
  4. Apr 5, 2018 at 11:46 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Ehh.. It's good wiring, but that kit is way more stuff than you need. You wouldn't need the long 4 channel RCA's, or the spool of speaker wire.
    ryneati[QUOTED][OP] likes this.
  5. Apr 5, 2018 at 11:47 AM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    I have all kicker wire in my truck. It's nice. The only thing that's not kicker in my system is my bass amp.
  6. Apr 5, 2018 at 12:02 PM
    mbrogz3000
    Northern NJ
    When it comes to power cabling, I prefer to use a little extra budget for the next kit size above what the current goal is. Nothing is worse than ripping out wire and having it sit in a box when it’s time to upgrade (although 4 gauge can become direct distro wiring since amps usually receive 4 gauge now instead of 8 gauge). It can always go int the next vehicle Nobody wants to buy used car stereo wire either.
    Here is the power kit I bought - looks like it’s cheaper now, possibly discontinued:
    https://www.sonicelectronix.com/item_45060_NVX-XAPK1D.html
    There are other versions and options for the kit.
  7. Apr 5, 2018 at 12:09 PM
    ryneati
    Ryne
    Raleigh, NC
    I've had Kicker before...would do Kicker again..but if I ever wanted to upgrade the head unit...they don't have it...and we've established my brand mix problem hahah
    Alpine has just such good head units! When I switched, that's all I've ever used since.
  8. Apr 5, 2018 at 1:09 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    veggtaco and ryneati[QUOTED][OP] like this.
  9. Apr 5, 2018 at 2:27 PM
    ryneati
    Ryne
    Raleigh, NC
    On this 9 wire multiconductor you said two rolls? This is 20ft, will I seriously need 40ft of that? Hahah!
    https://www.sonicelectronix.com/item_116007_Carwires-SW9000-20.html
  10. Apr 5, 2018 at 2:31 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    You don't need 40ft, but I wasn't able to make it there and back with just 20. i tried my hardest. It came out to like 12 feet each direction. HOWEVER I ran mine from the radio, over to the passenger side kick panel, down the door sills, then back across the back seat to the drivers side. So if your amp is on the passenger side, you could probably make a single roll work.
  11. Apr 5, 2018 at 2:31 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    You won't need 2 rolls. I only used one. You won't utilize the stock wiring at all that goes to the speakers so you don't have to go back to the head unit from the amps.
  12. Apr 5, 2018 at 2:33 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    See I did it using factory wiring. It's actually good wiring compared to most vehicles (given he's only going to be running 50w rms through it)
  13. Apr 5, 2018 at 2:37 PM
    ryneati
    Ryne
    Raleigh, NC
    Oh okay, and so where exactly am I running this shit too? Haha!! I thought this just connected to the harnesses behind the dash? (least that's what I had gathered or thought without doing extensive install research yet.
  14. Apr 5, 2018 at 2:41 PM
    ryneati
    Ryne
    Raleigh, NC
  15. Apr 5, 2018 at 2:43 PM
    #35
    newb13
    newb13 Well-Known Member
    greg
    winter park florida
    2016 sr5 DCSB v6 blue
    de-badge and tint,tri-fold tonneau,rims and tires
    this is the last thing i need to read! lol. orion.precision power,soundstream?? thats how old i am and im in orlando also. I agree the back of these trucks make it very hard to deal with a box. make the floor and back wall flat and zing-2 -12s and 2 amps and done! you have gotten alot of info
    from some guys i feel sound like they know their stuff! :hattip::fingerscrossed::thumbsup::anonymous:
    ryneati[OP] and Man of Steel TRD like this.
  16. Apr 5, 2018 at 2:44 PM
    #36
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    You are going to build your harness with the speedwire. It will connect behind the deck in between the head unit and the trucks harness. If you are running mids and tweets you can't use the factory wiring to go from the amp to the speakers though. You will not want to do a run back to the head unit from the amp to get the signal to the door speakers. You will want to run wire from amp to the crossover then from the crossover into the doors and up to the tweeters in the dash.
  17. Apr 5, 2018 at 2:45 PM
    #37
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    If he is running mids and tweets for the front he can't use the factory wiring because of the crossovers.
  18. Apr 5, 2018 at 2:46 PM
    #38
    ryneati
    Ryne
    Raleigh, NC
    Definitely! They've been way more than helpful!
  19. Apr 5, 2018 at 2:48 PM
    #39
    ryneati
    Ryne
    Raleigh, NC
    Oooh I see!
    Well...say I just skip the Tweets..will that make that all any less confusing? Haha *gasp* leave the tweets?! I know...but again..I never changed those in the past either so..just a thought :notsure:
  20. Apr 5, 2018 at 2:52 PM
    #40
    destin_meeks
    Destin
    Tuscaloosa, AL
    Why not? I did.
    ********* makes a harness and has a whole video on it. It's pricey though so I made my own :thumbsup:
