another suspension help thread
Discussion in 'Suspension' started by jttx, Jun 21, 2018.
  1. Jun 21, 2018 at 3:12 PM
    jttx
    jttx [OP] Well-Known Member
    Jonas
    Austin Texas
    2012 nautical blue TRD sport
    I know im throwing this into a sea of people who need help choosing their suspension, so heres another one.
    I am currently torn, between compression adjusters, and increased lift. I am equally torn between fox, king and icon but only because i lack information on Icon and King. Im planning to order most everything from headstrong offroad.
    Fox gives me compression adjusters, but only 2 inches of lift. I have a road armor front bumper that weighs 150 lbs give or take, so I would lose some of that even.
    https://www.headstrongoffroad.com/store/p191/FOX_Level_3_Kit_-_05__Tacoma.html
    Icon gives me up to 3.5 inches of lift, but on the headstrong page there is no option for compression adjusters, so im not sure if I can add those on.
    https://www.headstrongoffroad.com/s...004T_with_Delta_Joint_Upper_Control_Arms.html
    Last is king, which iv heard awesome things about, have compression adjusters, but i have no idea how much lift they provide.
    https://www.headstrongoffroad.com/s...ional_Compression_Adjusters_-_05__Tacoma.html
    any knowledge/ suggestions are much appreciated
  2. Jun 21, 2018 at 3:16 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Id go king with 700lb coils. Might take a phone call to get the right coils. @Downsouth Motorsports usually is great for help and good pricing.
    PS: ive had all 3 and king rides the best
    jttx[OP] and jeff b like this.
  3. Jun 21, 2018 at 5:06 PM
    jttx
    Jonas
    Austin Texas
    i
    figured they would. do you know if they provide any lift?
  4. Jun 21, 2018 at 6:11 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    If you buy the extended travel version, which all three offer, you can achieve 3” of lift. You will need new UCAs if you go this route. Icon calls it CDC adjusters, Fox calls it DSC and King I believe just says compression adjusters. Icons are preset so that a stock icon coilover is in the middle and then you can actually adjust softer or firmer, Fox is set for a non DSC coilover to be all the way soft so you can only adjust it firmer. No idea about Kings adjusters. Fox is also the only one that offers both high and low speed adjustments independent of each other only on 2.5” shocks.
