Another switch question
Discussion in 'Lighting' started by cmonjack, Apr 5, 2024.
  1. Apr 5, 2024 at 5:55 PM
    cmonjack
    cmonjack [OP] Active Member
    Utah
    2023 TRD-OR Double Cab Long Bed
    Didn’t realize there was a lighting forum so I posted this in 3rd gen. first but may find better info here.
    I was planning on running some ditch lights through a relay triggered by the high beams but also switched so I can run the high beams without the ditch lights. Simple enough...
    Now I'm wondering, if I use a two position (3 with off) so I can use them as stated (switch position 1) but also, switch position 2 would light the ditch lights without the high beams, would it cause a problem?
    Seams simple but do I need to worry about feedback to the high beam trigger wire?
    I'm going to mock it up this weekend but thought I would get some advice first
