Another tire/lift/rims post
Discussion in '3rd Gen. Tacomas (2016+)' started by dcai, Jul 23, 2018.
  1. Jul 23, 2018 at 9:17 PM
    dcai
    dcai [OP] Active Member
    David
    Montana
    2017 Black Tacoma SR5 4x4
    Hello all,
    First off I've been a lurker for a while and have been enjoying perusing all the posts and the great tips/advice. I have a 2017 Tacoma DCSB 4x4 and have been sitting on it trying in anticipation to put some work into it.
    I'm planning on adding some upgrades including an Icon Stage III lift with Billet UCAs and am shopping around for tires/rims for it. I've stalked the forum a bit and have decided on 285/70R/17s and am contemplating between the K02s and the Falkens. I'm looking at the SCS F5 rims and have been told that with this set up, I will most likely be rubbing and will need to trim. I just wanted to hear some opinions because from what I've read, it seems like this may work without the need to trim since it's been lifted. I can get it trimmed either way; I just was hoping to avoid it. Also I was going to get a full-sized spare but may just order a cheap steel rim for the spare. Will that fit in the stock spare spot or will it be too big? Thanks for the all the advice!
    I'm also planning on ordering these things and will post pics once I get her purrrty.
    1. Vengeance Bumper with Pre-runner Guard in Black Powdercoat
    2.Vengeance Rear Bumper in Black Powdercoat
    3. MagnaFlow Cat-Back Performance Exhaust System
    4. D-Series Dually 20 Deg. Flood and Spot LED Light to go on the front bumper
    ChadsPride likes this.
  2. Jul 23, 2018 at 9:21 PM
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    285/70/17's with aftermarket UCA's, depending on how much caster you get out of your alignment, you'll most likely have to trim something to make them fit. The reason why the F5 wheels rub is because of the back spacing of the wheel itself. I believe they are like 3.5? With that you'll probably be rubbing pretty good. I know the other SCS wheels are like 4.3 which is more ideal for you since you want trimming to minimum. As far as the spare goes, you can probably get a steelie with a tire with the same dimensions to make it fit under the bed? I'm running a full size spare so I can't really give any advice on that.
  3. Jul 23, 2018 at 9:25 PM
    dcai
    David
    Montana
    Thanks for the input. If I can find some rims with a 4.5 BS, think I could get away with not rubbing? Have always loved SCS but may have to go with something else if that makes my life easier.
    TacoZim likes this.
  4. Jul 23, 2018 at 9:28 PM
    TacoZim
    Bay Area, CA
    2008 DCLB
    Try looking at SCS Ray10’s or SR8’s. Both awesome wheels with 4.3 BS. I’m running SR8’s and clear the cab mount and only scrub on the rear of my fenders if I’m wheeling. Although with 285’s I think you’ll be rubbing regardless. Every truck is different as to each variable in each person’s setup will be different. I say send it and get what you want and shit’ll buff later.
  5. Jul 23, 2018 at 9:32 PM
    dcai
    David
    Montana
    yeah..was actually just looking at that... May have to just bite the bullet and do it lol
  6. Jul 24, 2018 at 12:27 PM
    dcai
    David
    Montana
    Spoke with scs,they didn't have the 17" SCS SR8s and it wasnt coming into the next shipment so i went with some Fuel rims instead. Placed the order for the roof rack, front/rear bumper,exhaust, rims, tires, lift kit, and LED lights today... excited to see how it turns out!
    Shoutout to Carl from 4wheelparts.com...he really hooked it up on the parts knocking off ~100$ off on the front bumper, rear bumper, exhaust, roof rack, and 25$ off each rim. His extension was 5122
    TacoZim likes this.
  7. Jul 24, 2018 at 5:06 PM
    TacoZim
    Bay Area, CA
    2008 DCLB
    Whats the BS on the Fuels?
  8. Jul 24, 2018 at 5:15 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    That's a nice suspension setup, you should be happy.
    As far as the F5s go, just to be clear they have 5 different configurations of them only 2 of which being the 'extreme' backspacing (3.5)
    That being said, if you like that look then go for it! Also, check out the Nitto Ridge Grapplers.
  9. Jul 24, 2018 at 5:25 PM
    TacoZim
    Bay Area, CA
    2008 DCLB
    Hi Chad :cheers:
  10. Jul 24, 2018 at 5:44 PM
    dcai
    David
    Montana
  11. Jul 24, 2018 at 5:59 PM
    ChadsPride
    :D :wave: :fistbump:
  12. Jul 24, 2018 at 6:04 PM
    dcai
    David
    Montana
  13. Jul 24, 2018 at 6:08 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    Chincoteague, VA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    All photoshopped. I have it on good authority its too tall to leave the garage.
  14. Jul 24, 2018 at 6:17 PM
    ChadsPride
    Thank you!​
    :rofl:
