Another Tire Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matt47025, May 31, 2013.
  1. May 31, 2013 at 11:10 AM
    Matt47025
    Matt47025 [OP] Member
    Near Cincinnati
    2020 Sport
    My 2013 4wd truck has the standard "steel" rims. 16" I believe.
    I was thinking about buying a set of rims off a 2012 4runner limited which are 18" and a lot wider. I'm not a tire guy and I don't know if there will be enough clearance. Anyone have any info on this?
    :confused:
  2. May 31, 2013 at 11:22 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Wheels should fit just fine running a 265 60 18 tire but might have to trim some if they rub but im not sure as I would need the backspacing and offset of the wheels to determine that.
    FYI 18's are a lot more costly of a tire than a 16 or 17
  3. May 31, 2013 at 5:08 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    They should fit, just check using the tire calculator here on the forum to get the the right height of your original tires or close to it so your odometer and gas mileage will still be good. I put the 2010 17 inch 4runner wheels on mine last week with 265-65-17 AT/2 tires.
