Another Totaled Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HisDad, May 3, 2021.
  1. May 3, 2021 at 9:01 AM
    HisDad
    HisDad [OP] Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    This isn't a "Is my Taco Totaled" thread because this one is has been and is gone to the great highway in the sky. Actually, it's more likely someone will buy it as a repairable. Maybe.
    2015 non TRD with about 160K on the odometer.
    It belongs to my neighbor's company, he's the owner. One of his crews was driving to a job and a guy hit them. More of a side swipe, but it caught the lower rear corner of the cab. Pushed the rear wall of the cab forward. Rear door won't open at all.
    Too much labor to fix because the interior would have to be stripped out to weld in a new corner panel.
    Oh, he's going out to buy another Tacoma because he really liked this one. He "discovered" Toyota because he saw how long my two Tundras lasted. He has a '16 Tundra as well, but he likes the Tacoma because it's easy to park in work zones.
  2. May 3, 2021 at 9:32 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That’s great! Your neighbor runs a business and needs to move on to keep his clients happy.
  3. May 3, 2021 at 9:40 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Alright, time to get a new Tacoma!
  4. May 3, 2021 at 10:15 AM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    The damage is not too bad, but considering it is a business truck with more than 30,000 miles per year (total of 160K), then it doesn't make sense to keep it and try to repair. It is not only the rear wall and lower left corner, but the front left side of the bed, and that is hard to repair, as well.
    Grossomotto likes this.
  5. May 3, 2021 at 10:30 AM
    HisDad
    Texas at last
    Isn't the bed side a bolt on part? It would seem to be an easy fix if it was just the bedside.
  6. May 3, 2021 at 4:03 PM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Perfect trail rig
  7. May 8, 2021 at 2:45 PM
    HisDad
    Texas at last
    So, my neighbor bought a used 2015 Tacoma Limited. White, four door, 4WD, V6, AT. I took a look at it and it's super clean. I stuck my head underneath quickly and it doesn't have all that much rust at all. The previous owner took good care of it. I don't recall the miles on it, but it's not much.
    It had really nice polished wheels that seemed a bit larger than stock, but I'm not sure.
    Where does the Limited fit in the hierarchy of trim levels? I looked on line and couldn't get a clear answer.
  8. May 8, 2021 at 5:01 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    I suppose you could consider the Limited the "luxury" version of the Tacoma. You get the top end sound system, 18" chrome clad aluminum wheels, some leather tid-bits and the SofTex seat coverings. Also came with the tow package, traction control and heated seats. In its day, it had near the most expensive base price. It's a nice package (as long as you're not allergic to a little chrome) and is as capable as most Tacomas in all but the most serious off roading.
    Cheers.
    Xrrman, TRDSport10 and HisDad[OP] like this.
  9. May 8, 2021 at 6:47 PM
    HisDad
    Texas at last
    ETA: Long Bed and also has the premium sound system with HD radio and XM.
    Thanks. I wasn't sure about the wheels because the chrome clad wheels seemed aftermarket. Everything you wrote matches what I saw. It was unlocked so I stuck my head in. It looked really clean in and out.
    He won't off road it, at least as far as I know. It's actually going to be a company truck and he owns the company. Kind of a shame for that to be a work truck, but I expect it will be the truck he uses the most often. It's good to be the boss!
    He'll put a cap on it so he can load it with his equipment and then a ladder rack on top of that.
