Another Towing Question
Discussion in 'Towing' started by USMCGRUNT, Oct 2, 2020.
  1. Oct 2, 2020 at 5:41 PM
    USMCGRUNT
    USMCGRUNT [OP] Well-Known Member
    Philadelphia
    2020 TRD Pro - Mag Gray
    Sorry to beat your eyes with another towing question, but this will probably be the one and ONLY time I am going to tow with my 2020 Pro. I am in a bind and need to pick up material tomorrow morning.
    Thoughts?
    - 12' dump trailer ~ 2500-3500 pounds
    - 4 yards of playground mulch ~ 400-800 pounds per yard
    - 1/2 yard crushed stone ~ 1200 pounds
    I know the Pro is 6700 pounds, I just wanted to see some opinions.
    Thanks!
  2. Oct 2, 2020 at 6:29 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Based on your numbers, worse case scenario you’re at almost 8000lbs. Over max, toooooo much weight. Make two trips and haul half each trip, problem solved. Or if buying from commercial retail have them deliver.
    Aquatic Tacoma likes this.
  3. Oct 2, 2020 at 6:31 PM
    USMCGRUNT
    Philadelphia
    Yeah I agree with you on worst case. I would definitely get it delivered if they will deliver it same day. That is my hold up right now. Like you said, worst case I just make a few trips. Thanks!
    Sprig likes this.
  4. Oct 12, 2020 at 9:22 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Assuming 3500lbs trailer
    Only 2 yards at max weight of 1600lbs
    And 1200lbs stones is 6300 which is barely within your tow spec.
  5. Oct 13, 2020 at 12:00 AM
    RyDog509
    RyDog509 Well-Known Member
    2020 Tacoma DCLB OR
    Even though it’s a one time thing also think of some state laws you might be breaking involving brake controllers. Most states it’s 3500lbs for a brake controller. It’s one of those things that eh 9999 out of 10000 you will be fine. But all of a sudden get in a wreck or something stupid and your life is ruined with hundreds of thousands in law suits.
  6. Oct 13, 2020 at 12:20 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d make multiple trips.
  7. Dec 19, 2020 at 11:55 PM
    bigsky911
    bigsky911 New Member
    bob
    2018 taco mt6
    Fab Four bumper
    I have pulled a 21 foot toy hauler it was around 5000 I had a 600 miles to tow that thin it took me over 10 hours and was getting 9 mph it was hell but u can do it
  8. Dec 20, 2020 at 1:01 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Rent a U-haul chevy with a V8 and a 10k capacity, one trip and cheaper overall on gas savings vs 2 trips depending on how far you're going and doesn't stress your tacoma transmission.
    Added bonus you'll have enough power to merge onto the highway.
  9. Dec 20, 2020 at 1:08 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    You will be fine. Get separate loads.
    3500 + 1600= 5100 lbs. Take two trips.
    3500 + 1200= 4700 lbs.
