Another TPMS thread sorry everyone.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PNWTacoTruck, Jan 15, 2022.
  1. Jan 15, 2022 at 9:08 PM
    PNWTacoTruck
    PNWTacoTruck [OP] Well-Known Member
    Brent
    Hi all,
    Just bought my first taco. 2010 ACLB SR5 V6 4X4.
    The tires are all pumped to spec 30lbs. I'm getting the tire pressure dash light.
    At my pre purchase inspection the guy tried to pump them to 35lbs, still have the light.
    1. Could it be the spare?
    2. I'm almost leaning towards buying new tires, any way to find out with the tires off if the sensors are good or bad? Or should I just replace them all...
  2. Jan 15, 2022 at 9:10 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Is the light initially blinking and then going solid, or just solid?
    Dm93 likes this.
  3. Jan 15, 2022 at 9:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Those sensors (if original) are 11 yrs old, the batteries are likely dead. If you want the system to function as designed I would just buy a new set and install them with the new tires
    You can check them on the vehicle with a hand-held tpms tool
    Dm93 and JoshS like this.
  4. Jan 15, 2022 at 9:16 PM
    PNWTacoTruck
    Brent
    the light initially blinks on startup and then sits solid
  5. Jan 15, 2022 at 9:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A blinking light indicates a problem with the system (usually no signal from one or more of the sensors), any tire shop should have a tool to test the sensors.
    2015WhiteOR likes this.
  6. Jan 15, 2022 at 9:26 PM
    2015WhiteOR
    Gainesville TX
    Yep sensors are probably just dead. Can't recall if a 2010 would have TPMS in the spare, but I believe for that era, the way to know is if the valve stem has a flexible rubber shaft (no TPMS) or a solid metal one (TPMS).
    If you are wanting a TPMS replacement that matches OEM without the Toyota premium price:
    Amazon.com: Denso 550-0103 TPMS 315-MHZ Sensor for Factory Alloy Wheel Options : Automotive
    10thMTNgrunt likes this.
  7. Jan 15, 2022 at 9:45 PM
    PNWTacoTruck
    Brent
    Are the sensors programmed with specific codes (like my 2019 outback) or will a set of newer wheel/tires swapped in clear the code?
    There are a lot of OEM takeoffs around me on Craigslist. If throwing those on for $300 will give me more tread and no code I'd do it.
  8. Jan 15, 2022 at 9:47 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They need to be the correct ones for your truck and the sensor ID's will need to be programmed into the TPMS ECU.
  9. Jan 15, 2022 at 9:48 PM
    2015WhiteOR
    Gainesville TX
    Our TPMS system is not adaptive. Must be programmed via OBD. Stupid as hell and just increases the cost of ownership.
  10. Jan 15, 2022 at 9:52 PM
    PNWTacoTruck
    Brent
    Just like the subie. Ugh. How many people just disable the light? I have a gauge, and my gas station gives free air when you get fuel.
  11. Jan 15, 2022 at 10:05 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    I drove around for at least 4 years with a piece of black electrical tape covering the
    lighted TPMS icon on my speedo.
  12. Jan 15, 2022 at 10:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd fix it. A few bucks to keep the system working and the light off is no big deal. I'm not driving around with tape over warning lights, that shit is for kids
  13. Jan 15, 2022 at 10:41 PM
    2015WhiteOR
    Gainesville TX
    You can build a "TPMS pipe bomb", tinker with some wires inside the dash, or just unplug the TPMS receiver which is inside the headliner toward the rear of the cab.
    PNWTacoTruck[OP] likes this.
  14. Jan 15, 2022 at 10:43 PM
    PNWTacoTruck
    Brent
    I’d like to do whatever is easiest. First I’ll ask Le Schwab for a scan, and if they are dead, I’ll figure it out.
  15. Jan 16, 2022 at 3:53 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    They stopped putting sensors in the spare after 2008. Typical life for the sensor batteries is 7-10 years so you probably need new ones. The ones in my Tacoma were still working after 14 years which happens sometimes. But I ordered new sensors and had them installed when I bought new tires about a year ago. No issues at all with the ones I bought from Amazon.
    There was no extra charge when mounting the tires. But since mine is a 2007 I had one in the spare so I had to buy a 5th sensor. And since the spare was over 10 years old I had to pick up another newer used tire for a spare. That was a bit of a hassle. I paid $80 for a set of 4 from Amazon. The 5th one bought individually was $25 IIRC.
    I don't understand guys who will spend $800-$1200 for tires that have to be replaced about every 3 years, then bitch about spending $80 every 10 years on something that will help make the tires last longer and will warn you of a sudden tire deflation while you're driving. The TPMS isn't a substitute for an air gauge. And an air gauge won't tell you what is happening while you drive.
    PNWTacoTruck[OP], Dm93 and Dan 77 like this.
  16. Jan 16, 2022 at 9:37 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    The glue from the black electrical tape etched the lense covering my speedo anyway!
    This "kid" is 68 years old and a cheap old man. I bit the bullet and had all my sensors replaced with a set of new tires. Spare tire sensor too.
  17. Jan 16, 2022 at 9:45 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    :rofl:
  18. Jan 17, 2022 at 5:39 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  19. Jan 17, 2022 at 10:04 AM
    PNWTacoTruck
    Brent
    I don't really want to disable the system. My dilemma is that the tires are prob at 50% life so I have to decide if I want to put new sensors in old tires, or get new tires that I don't need yet. Thanks for the feedback everyone!
  20. Jan 17, 2022 at 1:36 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Just a bit of info... Daughter just bought a 2010 Matrix last Friday. Had the blinking TPMS indicting one or more sensors are bad. I sent her to Les Schwab. One bad sensor, $98 total.
