Another transfer and diff fluid change question....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thelate1, Feb 25, 2021.
  1. Feb 25, 2021 at 8:40 AM
    thelate1
    thelate1 [OP] Well-Known Member
    PA
    2013 DCLB Sport 4x4
    I have a 2013 DCLB Sport 4x4. My truck is now out of warranty so I'll be doing the fluid changes myself from here on out. I've read every one of the threads on this topic and my only hang up is the mixed info on needing to add modifiers to the transfer case. I plan to use Mobil 1 75/90 in all three (front and rear diff and transfer case). I've read that I do and don't need to add modifiers to the transfer case. Confirmation would be much appreciated. I know there is always brand debates but the Mobil 1 seemed to be a solid choice.
  2. Feb 25, 2021 at 9:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Always done my own oil changes on everything. Any 75w-90 gear oil in front n rear and tcase no modifiers outside of packaged LSD additives in most gear oils never an issue, tcase always goes right in.
  3. Feb 25, 2021 at 11:13 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Any of the modern GL-5 75w90s will do the job for both diffs and the TC.
    I prefer a synthetic to allow for a little flexibility in fluid change time (I.e. I don’t worry about driving 40k rather than 30k, etc.) YMMV.
    wi_taco and thelate1[OP] like this.
  4. Feb 25, 2021 at 12:00 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  5. Feb 25, 2021 at 2:25 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    ABNFDC[QUOTED] likes this.
  6. Feb 25, 2021 at 5:19 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I'm not a big fan of Walmart, but their Super Tech Synth 75W90 gear fluid is super affordable and has great reviews.
    thelate1[OP], Markcal and confirm45 like this.
  7. Feb 26, 2021 at 5:02 AM
    thelate1
    PA
    2013 DCLB Sport 4x4
    I was just looking for other opinions. Just like other truck maintenance that's discussed on here, there are always options outside of the manual. :cool:
  8. Feb 26, 2021 at 5:17 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Thats what I use in my diff, no problems
    confirm45[QUOTED] likes this.
  9. Feb 26, 2021 at 6:23 AM
    Knute
    Agreed. Although, the manual will have the specifics for API grade, viscosity and quantity. Anything that meets or exceeds the specs is perfect.
    thelate1[QUOTED][OP] likes this.
  10. Feb 26, 2021 at 7:28 AM
    Captain_Blue
    Captain_Blue Member
    2013 4.0L TRD Sport 4x4 DCLB
    Hello all. I just made my account to post in this thread, longtime lurker.
    Just bought my first Tacoma, same as the OP, at 59K miles, and figured this was the perfect time to ask questions on this topic.
    I have very little knowledge of the mechanics of a vehicle and the most maintenance I've done is an oil change.
    Anyway, If I'm reading this thread right, it would be ok to use
    https://www.amazon.com/dp/B07F31DQQJ
    for both the Transfer case and differentials? Like literally the same oil?
    thelate1[OP] likes this.
  11. Feb 26, 2021 at 8:47 AM
    nd4spdbh
    SoCal
    Yup. Buy 6 quarts, 1.6 in the front diff, 1.4 in the tcase and 3 in the rear axle.
    This thread reminds me.... i need to get fluids for front,tcase,rear,trans fluid change out at 120k miles coming up soon.
  12. Feb 26, 2021 at 9:08 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Thats the choice of many from TW.
  13. Feb 26, 2021 at 9:18 AM
    Captain_Blue
    Captain_Blue Member
    Thank y'all so much. I love this vehicle, but having an old 2007 Hyundai as my first car, this truck is a way different beast. I've learned a ton in the past few weeks. I'll order 6 quarts soon, and attempt to do these fluid changes on my own. I've probably watched about 10 YT videos, and it seems fairly straightforward.
  14. Feb 26, 2021 at 9:38 AM
    nd4spdbh
    SoCal
    Spray some penetrating oil (pb blaster, aero kroil etc) on drain and fill plugs, especially on the front diff. Also make sure to take a pick and clean out any debris on the front diff allen drain n fill plugs so your allen wrench seats all the way in.
    Lastly, ALWAYS loosen the fill plug before the drain plug. You want to make sure you can actually put oil in before draining stuff out haha.
  15. Feb 26, 2021 at 9:43 AM
    Captain_Blue
    Captain_Blue Member
    Will do! Thanks!
    Those sound like some decent tips.
  16. Feb 26, 2021 at 9:57 AM
    Knute
    Another point or 2.
    Before you begin, swing by the Toyota dealer to get all the plug gaskets.
    When putting the plugs back in, don't gorilla arm them. They are simply plugs, treat like the oil pan drain plug. Firmly snug. No leak, then tight enough.
  17. Feb 26, 2021 at 10:09 AM
    nd4spdbh
    SoCal
  18. Feb 26, 2021 at 10:14 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
  19. Feb 26, 2021 at 3:43 PM
    Captain_Blue
    Captain_Blue Member
    Thanks for the tips, y'all. I'll order some fresh gaskets!
