Another transfer case leak thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by HCFab, Feb 27, 2019.
  1. Feb 27, 2019 at 11:44 AM
    HCFab
    HCFab [OP] Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    EDIT: OK I found more info after searching a little more. Looks like it is a 90311-41012
    And I'll need a fluid pump, 2 Quarts of 75w90 Gear Oil, and a new tube of Lucas - Red N' Tacky #2
    Sold on Amazon here: https://www.amazon.com/Genuine-Toyota-90311-41012-Type-T-Transfer/dp/B00GFI2EFU/ref=pd_bxgy_263_img_2/130-3385109-5568702?_encoding=UTF8&pd_rd_i=B00GFI2EFU&pd_rd_r=f827e4e5-3ae0-11e9-9500-39d562a2f7fe&pd_rd_w=zBcQP&pd_rd_wg=MXyw1&pf_rd_p=6725dbd6-9917-451d-beba-16af7874e407&pf_rd_r=N1Q2JD9X8GDXFS8G30BK&psc=1&refRID=N1Q2JD9X8GDXFS8G30BK
    More threads with more info: https://www.tacomaworld.com/threads/transfer-case-leak-pics-help.11657/
    https://www.tacomaworld.com/threads/transfer-case-leaking.537563/
    https://www.tacomaworld.com/threads/transfer-case-severe-leak.486835/
    https://www.tacomaworld.com/threads/transfer-case-leaking.100871/
    Original Post:
    I did some searching on the forum and I cant find a definite answer to which seal is needed for the transfer case output shaft to the front dif. I'm familiar with the job via YouTube and already have a seal puller. I just need to figure out the specific seal and get it ordered ASAP. Also I'll need some more trans fluid, its been leaking for a few weeks now I'm assuming it's OEM oil in there.
  2. Feb 27, 2019 at 1:00 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    In same boat... subscribed
    HCFab[OP] likes this.
  3. Feb 27, 2019 at 3:09 PM
    HCFab
    Zach
    Central Idaho
    I dug up some more info for ya bud, That should help both of us out.
    Cheers!
    pray4surf[QUOTED] likes this.
