Another transmission idea?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by leonharu, Apr 8, 2023.
  1. Apr 8, 2023 at 2:48 PM
    leonharu
    leonharu [OP] Well-Known Member
    Russell
    I am not a transmission expert but seems like the tranny shifts and operates the best when cold.There has to be a sensor or something somewhere that reads the temperature,so why not unhook it or clip the wires and see what happens?
  2. Apr 8, 2023 at 2:52 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Torque converter is not On until 110°F.
    SH10151 and ConantTaco like this.
  3. Apr 8, 2023 at 3:43 PM
    leonharu
    Russell
    Ok,I know I had a 1983 Chevrolet truck that started getting a vibration or stumble to it when the torque converter would lock up.I took it to a mechanic to look at and he said he just unplugged it?Never had any more issues with truck,always shifted perfect after that!
  4. Apr 8, 2023 at 4:04 PM
    Vlady
    Issy, WA
    need to cut wire(s) to SLU solenoid. Here is the diagram
  5. Apr 8, 2023 at 4:06 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My transmission is more efficient when the truck is fully up to operating temp. Transmission feels like it's stuck in 5th gear otherwise. As far as shifting, its very smooth, and on cue all the time.
    Skydvrr likes this.
  6. Apr 8, 2023 at 4:18 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    This isn't 1985, mods like that don't work anymore. :pout:
    1) Check engine light will be on because the computer can tell that the converter isn't locked. Probably end up in a limp mode.
    2) Even if it did work the transmission temperature would be very high due to the converter slip.
  7. Apr 8, 2023 at 4:51 PM
    Vlady
    Issy, WA
    You missed a joke...
  8. Apr 8, 2023 at 4:52 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Wow
    Chew likes this.
  9. Apr 8, 2023 at 5:54 PM
    leonharu
    Russell
    Where is temperature received from?
  10. Apr 8, 2023 at 6:29 PM
    Vlady
    Issy, WA
    2 sensors inside the tranny.
    Just get a tune. You are on the wrong path
    RustyGreen, joba27n and na8rboy like this.
  11. Apr 8, 2023 at 7:10 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Just here to say I agree. Truck not warmed up, especially in ECT mode is much better shifting. Transmission becomes obsessed with its 5th gear once warm and hates downshifting from it.
  12. Apr 8, 2023 at 7:25 PM
    23TRD
    23TRD Active Member
    2023 Trd off road access cab auto
    I’m still confused about all the tranny shifting complaints . I’ve had my 23 trd off road about 6 weeks now and put almost 4000km on it .
    I’ve driven it in all types of conditions.. highway in the flats as well as in the mountains.. with cruise on amd without .. city .. off road lots . And I have zero complaints with this truck and it’s transmission.
    I do notice that it upshifts a touch soon sometimes amd then needs to downshift again . But all modern autos do that . They are trying to keep the rpm’s as low as possible for fuel economy. My last 4 new trucks have all been fords, starting with a 2010 f150, then a 2013, then a 2016 .. then a 2019 super duty f250 gas v8 . These all had 6 speed autos .. amd they all shifted similarly to the Toyota . Always eager to get to the highest gear possible. It is a bit annoying sometimes, but I’ve come to accept it with modern autos. The fact that the v6 in the Tacoma makes it hp and torque at higher rpm’s does make for more shifting than a v8 would require … but it is what it is .
    Overall, I think the Tacoma shifts nicely and predictably.
  13. Apr 9, 2023 at 1:05 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Agree. I've had mine about a month now and have around 700 miles on it. I don't find anything objectionable about the transmission. Let's just hope it stays that way as it "learns" how I drive!
