Another Truck?! Third Time's the Charm TURBOCHARGED
Discussion in '1st Gen. Builds (1995-2004)' started by Speedytech7, Dec 14, 2022.
  1. Dec 7, 2024 at 1:27 PM
    #341
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I was promised 500.
  2. Dec 7, 2024 at 1:30 PM
    #342
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It was close. But we cracked 400 wheel hp so I'm pretty stoked on that still. You have to know when to stop sometimes. The boost is willing but the engine is still very much stock bottom end.
  3. Dec 7, 2024 at 1:34 PM
    #343
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Clutch didn’t start slipping yet?
  4. Dec 7, 2024 at 1:36 PM
    #344
    6P4
    Colorado Springs
    For sure, a reliable (assuming it holds) 480tq is much more impressive than a single 500tq run and then a new engine.
  5. Dec 7, 2024 at 1:38 PM
    #345
    Speedytech7
    Not even a little, datalogs from the Dyno and the Haltech are in sync
    drr[QUOTED] likes this.
  6. Dec 7, 2024 at 2:02 PM
    #346
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hot damn dude. That's awesome
  7. Dec 7, 2024 at 2:42 PM
    #347
    Speedytech7
    I'm excited to show the full graphs too, like don't get me wrong the peaks are cool and I'm glad we hit em, but now the power comes on earlier and stays up as the RPM keeps going. We learned some things about the 5VZ this time as well, we went at it with the knock ears and did pass after pass of little changes to see what a degree of timing does, what a pound of boost does, what effect those have if we ramp them at different RPM, where additional timing stops making a difference... etc This thing did pass after pass of 470+ lb pulls haha
    unstpible and jubei like this.
  8. Dec 7, 2024 at 5:46 PM
    #348
    Speedytech7
    @6P4 we also ran that 91 pickup with the turbo 2RZ that you saw us building a few pages back. I'll have graphs and everything for that pretty soon too.
    But it made 316whp 338wtq at 15.3psi
    unstpible likes this.
  9. Dec 7, 2024 at 5:56 PM
    #349
    6P4
    Colorado Springs
    How do you feel about the potential of the 2RZ? I know it's been used as the basis for 1000hp drag builds but that's obviously with a ton of work. What's it good for in stock form? Are you already pushing the limit?
  10. Dec 7, 2024 at 6:13 PM
    #350
    Speedytech7
    It seems excellent. It flows better at the top end then a 5VZ does that's for sure. We would love to be able to turn this one faster because the graph suggests that it would just keep on going if we had the duty cycle turned up. But an abundance of caution kept us from exceeding 6000rpm with stock valve springs and buckets. No concerns on the bottom end though and it isn't knock limited that we could tell. Seems to really like boost and is pretty unstressed
    unstpible and 6P4[QUOTED] like this.
  11. Dec 7, 2024 at 7:32 PM
    #351
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah super impressive. Just makes me want to do it more haha
  12. Dec 7, 2024 at 8:11 PM
    #352
    Speedytech7
    Here's the new graph superimposed over the old. Can pretty much ignore below 3000rpm, it's a difference in how much throttle I use to roll in.
    TMFF, Digiratus, jubei and 1 other person like this.
  13. Dec 7, 2024 at 10:42 PM
    #353
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Looks like you picked up a few more mph on the top speed too, must be better aerodynamics from the new windshield
    Speedytech7[OP] likes this.
  14. Dec 7, 2024 at 10:51 PM
    #354
    Speedytech7
    6000rpm seemed like a nice redline :)
  15. Dec 18, 2024 at 7:34 AM
    #355
    Speedytech7
    Winter trip got cancelled so truck is in full mothball mode for maint. Working on battery relocate stuff, new radios, air compressor... trying to decide if I want to dump more money and get a Nexus S3... you know normal truck things.
    ABA180 and jubei like this.
  16. Dec 18, 2024 at 10:30 AM
    #356
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Radios? Plural? I have 4 of them installed now. :bananadead:
  17. Dec 18, 2024 at 10:33 AM
    #357
    Speedytech7
    I took the CB out and chopped the mount off my rack. But I am working on getting the GMRS installed and I left a spot for a HAM and ran power for it just in case.
    Digiratus[QUOTED] likes this.
  18. Dec 18, 2024 at 10:35 AM
    #358
    Digiratus
    Roaming the PNW
    The RedHead
    I've left my CB in for now.
  19. Dec 18, 2024 at 11:56 AM
    #359
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    GMRS you say? So when I replace my CB with one I won’t be talking to myself?
  20. Dec 18, 2024 at 12:00 PM
    #360
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Wow. What boost are you up to?
