Another Truck?! Third Time's the Charm TURBOCHARGED
Discussion in '1st Gen. Builds (1995-2004)' started by Speedytech7, Dec 14, 2022.
  1. Jan 13, 2025 at 11:28 AM
    #381
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    got it. Well I guess I'll have to go to a pick n pull yard and look around to try and find something that would fit well
  2. Jan 13, 2025 at 11:31 AM
    #382
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I get the feeling that the minivan ECU you were using probably did some sort of duty cycle control e fan to begin with. Have you explored whether that output is usable for you?
  3. Jan 13, 2025 at 11:33 AM
    #383
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    it did, I kinda have, I'm pretty confused why no-one in the MR2 world uses the ECU to drive their fans.
  4. Jan 13, 2025 at 12:27 PM
    #384
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Found it.
    And now following it. :mudding:
    Speedytech7[OP] likes this.
  5. Jan 13, 2025 at 12:33 PM
    #385
    TnShooter
    Deogee
    STOCK
  6. Jan 13, 2025 at 12:48 PM
    #386
    Speedytech7
    Yeah, that's a concern for sure. Have a line on some forged rods with 3/8" ARP hardware though if that ends up being a failure mode. I think mine will be okay but the race truck might need em haha
    TnShooter[QUOTED] likes this.
  7. Jan 27, 2025 at 6:54 AM
    #387
    Speedytech7
    Getting started on the flatbed project, I forgot to take a picture yesterday of the wooden frame plan we knocked together, but I'll do that as more of the plan comes together. Going to buy steel today so I can at least get the bed frame portion knocked out and welded on. Also have some frame boxing plates to install while this is all apart.
    BossFoss, jubei, TnShooter and 8 others like this.
  8. Jan 27, 2025 at 8:39 PM
    #388
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  9. Jan 27, 2025 at 8:52 PM
    #389
    Speedytech7
    I aim to entertain. You don't troll my other thread but I should post it in here too. I'm getting rid of the stock gas tank, 42 gallon suburban tank in my future.
    turbodb, unstpible and Dalandser like this.
  10. Jan 27, 2025 at 9:11 PM
    #390
    TnShooter
    Deogee
    STOCK
    On this truck?
    If so, what side of the axle?
    That's a big tank......
  11. Jan 27, 2025 at 9:12 PM
    #391
    Speedytech7
    It's gotta go behind, there's no room for it ahead of the axle, but the 42g tank is confirmed to fit in the space. Old gas tank location I have some other plans for
  12. Jan 27, 2025 at 9:15 PM
    #392
    TnShooter
    Deogee
    STOCK
    I just looked it up.
    It's about as wide as it is long.
    Will it hang down much?
    You know, for ground clearance reasons?
  13. Jan 27, 2025 at 9:16 PM
    #393
    Speedytech7
    Hangs about the same amount as the spare tire would in the same location. I'm still kind of waffling between using the 42 gallon version or the 30 gallon I'm undecided. The 30 gallon saves two and a half inches. But I've got room to move this big tank up another 4 in because of the new bed design too
  14. Jan 27, 2025 at 9:26 PM
    #394
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    42 gallons would be awesome for those long drives or just not having to fill up more than once during the winter
  15. Jan 27, 2025 at 9:26 PM
    #395
    TnShooter
    Deogee
    STOCK
    You can put 30 gallons in a 42. But you can't put 42 in a 30. ;)
  16. Jan 27, 2025 at 9:30 PM
    #396
    unstpible
    Derek
    Cedar City, Utah
    Sure you can it just leaves 12 gallons on the ground when your done
  17. Jan 27, 2025 at 9:33 PM
    #397
    Speedytech7
    Man I did that the other day, walked away from the BMW for like a half second to go get a window squeegee and the thing didn't shut off and gas ran down the fender :bananadead:
    unstpible[QUOTED] likes this.
  18. Jan 27, 2025 at 10:18 PM
    #398
    Blackdawg
    Monte
    Wyoming/St. Louis
    I believe @BossFoss has said if he did it again he'd do the 30 just because the 42 hung down so low. I think its lower than the spare a bit.
    Also weight. That's a lot more weight in fluids.
  19. Jan 27, 2025 at 10:37 PM
    #399
    Speedytech7
    It's 262# when entirely full, he kept the stock tank though, which I see no point in having at all if you've got 42 gal
  20. Jan 27, 2025 at 10:39 PM
    #400
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sure. I just mean he was more concerned with how low in hung down. 30 gal is still 280-500miles range pending your mpgs haha Plus you could still use a jerry or two for just in case.
    Then again with this whole build out, your wheeling style in general could change given the weight, potential height/width of it too.
