Another Truck?! Third Time's the Charm TURBOCHARGED
Discussion in '1st Gen. Builds (1995-2004)' started by Speedytech7, Dec 14, 2022.
  1. Feb 3, 2025 at 8:10 PM
    #441
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I still loved how Frankenstein sounded with just the 14" magnaflow. Was awesome.
    Piping to the rear is 10000x worth it though. Even dumping under the bed is obnoxious in the cab.
  2. Feb 4, 2025 at 7:27 AM
    #442
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Okay, weird distraction exhaust project is wrapping up now, just have to slap a couple more hangers on. But it is a nice and easy three piece system to put on and remove now with v-bands. Downpipe, mid-pipe with muffler, then rear pipe with resonator. I kinda feel like we did too nice of a job for what is supposed to be temporary haha. But all of the rasp is gone now, it sounds pretty different can't say I've heard another exactly like it before. Also it is quiet in the cab and I'm all about that.
    https://youtu.be/ycIZDWU11YA
    Kind of got screwed by the auto gain on the microphone for the interior shot because it adjusted because of how quiet it is. But one indication that it's quiet is how you can hear the motors mechanical sound more than the exhaust now.
    https://youtu.be/ym68LmQZsbo
  3. Feb 4, 2025 at 7:35 AM
    #443
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Looks good and sounds good too:thumbsup:
  4. Feb 4, 2025 at 7:36 AM
    #444
    BassAckwards
    We need another clip with some turbo noises:D
  5. Feb 4, 2025 at 7:37 AM
    #445
    Speedytech7
    Thanks!
    I think I can arrange that in the near future :D
    BassAckwards[QUOTED] likes this.
  6. Feb 4, 2025 at 7:49 AM
    #446
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I was thinking about it the other day and I'm pretty sure I have the 14" under mine now, made that change when I routed it out the rear. It is way better than the 18" that just had a turn-down under the bed. With two cats I have never had any drone and find the outside and I side noise a good balance. To your point routing it out the back is key. Same with the recent muffler delete on my diesel, while it is bassy in some spots, the inside volume is acceptable mostly because it dumps 40 feet away :laugh:
  7. Feb 4, 2025 at 9:44 AM
    #447
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I like the sound. Quite a bit quieter. Is that 3" all the way back now?
  8. Feb 4, 2025 at 9:50 AM
    #448
    Speedytech7
    Thanks! It is 3" the whole way through
  9. Feb 4, 2025 at 10:03 AM
    #449
    Digiratus
    Roaming the PNW
    The RedHead
    That has the potential to change power levels too because of less restriction doesn't it? Be interesting to see what effect it has in that area.
  10. Feb 4, 2025 at 10:05 AM
    #450
    Speedytech7
    It was 3" before too, just hidden under the bed, I don't know if my exhaust was ever a choke point (highly doubt it) if it was then power will have gone down now a little because extra length and bends, but if it wasn't (keeping in mind my daily tune is around 380ish HP) then nothing should have changed.
  11. Feb 4, 2025 at 5:49 PM
    #451
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lame. So quiet! Engine is louder than anything haha I want that constant turbo whistle!
  12. Feb 4, 2025 at 5:54 PM
    #452
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah you basically tried to copy franks setup. Never did sound the same. Probably because your truck has two cats and Frank has one and different header styles too.
    But yes. Dumped exhaust = bad time. Unless it's the very quiet stock muffler haha
  13. Feb 4, 2025 at 6:28 PM
    #453
    Speedytech7
    Turbo's still plenty loud just on the intake side now which is good enough. Could never hear the exhaust side of it in the cab anyway, just heard drone mostly and rasp at the very top end. I would think the guy that wears ear plugs to take a dump would appreciate a quieter exhaust.
    Blackdawg[QUOTED] and m3bassman like this.
  14. Feb 4, 2025 at 6:44 PM
    #454
    Digiratus
    Roaming the PNW
    The RedHead
  15. Feb 4, 2025 at 8:32 PM
    #455
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Do the Toyotas do that? They make this strange sound that's annoying and hard to describe. Feel like when skynet is active it will be the sound you hear when the machines are near and its time to take cover lol
  16. Feb 4, 2025 at 8:34 PM
    #456
    Speedytech7
    Yeah I think it's a mandate for newer electric cars they have to make some sort of noise so pedestrians can easily notice them when they're not fast enough to be making tire noise
  17. Feb 4, 2025 at 8:38 PM
    #457
    BossFoss
    Wyoming
    01 DC Tacoma
    Ah, makes sense, I thought it was a charging or electric motor noise but that didn't make sense to me
  18. Feb 4, 2025 at 9:27 PM
    #458
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean quiet in the cab sure. But I wanna let er rip with the windows down! And I was always surprised how quiet the turbo noises are on your truck. Idk why. Want the MKIII supra whistle after you slap 3'' cat back exhaust on it.
    m3bassman likes this.
  19. Feb 4, 2025 at 9:30 PM
    #459
    Speedytech7
    You should hear it now in the cab when it comes up to 15psi. It has a pretty sharp change in tone around 10 psi. But it's not a straight pipe so you don't hear like the little exhaust whistle at idle and low throttle, the only time I've ever heard that on cars is when they don't have a muffler at all like my 135i. That's usually also more pronounced when your turbo is too small.
    Blackdawg[QUOTED] likes this.
  20. Feb 4, 2025 at 9:36 PM
    #460
    Blackdawg
    Monte
    Wyoming/St. Louis
    The whoosh sounds I'm sure are awesome.
