Another Truck?! Third Time's the Charm TURBOCHARGED
Discussion in '1st Gen. Builds (1995-2004)' started by Speedytech7, Dec 14, 2022.
  1. Feb 3, 2023 at 4:10 PM
    #41
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's a newer development haha
  2. Feb 6, 2023 at 8:14 AM
    #42
    Speedytech7
    Well, last year I fixed the frame and painted it all fresh behind the front suspension... but then I ground the back a bit and welded in the shock relocate and made the mistake of spray painting it. So I went back now and gave everything a fresh coat of primer and paint. It is much nicer doing this in a climate controlled shop rather than hoping my ghetto ass garage at the last place would stay warm enough with a space heater. Thankfully it was mostly just the x-members and the shock relocate. But I did one extra coat of paint on the frame as well for good measure.
    The forbidden Choco-pop
    Spray paint clearly didn't do so well compared to the good stuff I used on the rest of the frame
    Primed!
    Painting stuff isn't fun without a beer or two
    Nice and clean, I'll pop the cross-members and the tank back in and be ready to yank the engine out now.
    Bandido, Yetimetchkangmi and gordi like this.
  3. Feb 6, 2023 at 9:44 AM
    #43
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is brushing on the primer preferred over rattle can?
    I've been curious how critical that rear cross member is. I never put mine back on and wonder if I should.
  4. Feb 6, 2023 at 9:49 AM
    #44
    Speedytech7
    This primer and paint combo I really like only comes in cans, you can thin it and spray it out of an airless paint sprayer I guess but I find it easy (and less noxious) to brush it on using a foam roller and regular/foam brushes). I don't like how the frame feels without that crossmember, it adds a lot of rigidity.
  5. Feb 6, 2023 at 9:59 AM
    #45
    Digiratus
    Roaming the PNW
    The RedHead
    I was thinking the same. Those frame ends can move around quite a bit even with the heavy swing out bumper. I think the next time the bed is off for repairs I'll reinstall that cross member.
  6. Feb 15, 2023 at 12:19 PM
    #46
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Did cleaning the contact on the fuel level sender help with the cluster gauge readout at all?
  7. Mar 29, 2023 at 1:54 PM
    #47
    Speedytech7
    Yeah it doesn't jump around 45mi into a tank anymore. It just does what it is supposed to. Soft pencil eraser took the carbon right off and a little alcohol cleaned it up.
    jubei and betterbuckleup[QUOTED] like this.
  8. Apr 10, 2023 at 10:50 AM
    #48
    Speedytech7
    Uh-oh I have been shirking my responsibilities updating this thread. I drove the old girl for a week after putting my rear back together again and then decided driving it was too easy and enjoyable. So I took it apart again, this time in front.
    Mandatory picture before the murder
    Removing the heart...
    I went and got a new stand for the engine since my other was holding a Mercedes diesel engine
    Grabbed the turbo kit out to take some measurements at first.
    Then a tiny modification to a used ECU to fit my new standalone
    And I'll leave it with a quick mock-up on the engine stand
  9. Apr 11, 2023 at 9:17 AM
    #49
    Speedytech7
    I didn't really take pics of the valve cover gasket job or the turbo oil drain bung I welded onto the oil pan. Neither is anything new or unusual and you can find examples of either on TW elsewhere. But I cleaned up the oil nightmare from the leaking VCs and plopped the engine back in with much help from @Digiratus. This was a good time to do the clutch, so in goes the pinkest Exedy Racing clutch.
    Then I swapped out the factory coolant temp sensor for one from a Chevy LS engine so I could have more accurate readings in the Haltech.
    Took a small break and decided to weld on some coilover tower reinforcements.
    Then sandblasted and used some JB weld to repair the sloppy pin fitment in my shifter turret.
    Okay back to engine work. Installed some 650cc injectors and new fuel rail washers.
    And ran the oil feed line for the turbo (wasted hours getting fitting position and routing decent)
    Okay now we're caught up for a min I think
  10. Apr 19, 2023 at 9:47 AM
    #50
    Speedytech7
    Started wiring my engine harness for the changes I want to implement in the Haltech.
    One of the biggest changes was removing the ground splice for the crank and cam sensors. This is an undocumented splice in the Tacoma harness, no EWD shows this.
    Got my tight radius full flow -10AN 45 fittings and made a drain hose for the turbo.
    Made a new bracket to hold my igniter so it isn't on the fender anymore.
    Tapped a hole in the intake for a new AEM IAT sensor (uses the GM calibration)
    chrslefty, Trim taco, jubei and 2 others like this.
  11. Apr 19, 2023 at 12:44 PM
    #51
    Speedytech7
    Okay, so since I started changing pinouts and needed to keep track of things I created a new reference sheet, probably not helpful for anyone else but I'll keep it here.
    jubei and Bandido like this.
  12. Jun 30, 2023 at 6:49 AM
    #52
    Speedytech7
    Huh, I guess I should probably update this... the truck is back together and man does it rip. It was tuned on just 4psi while I checked everything and now with the intercooler plumbed in it is pushing 9-10psi.
    The intercooler needed a tiny bit of work to fit, so a buddy welded a 3" aluminum 90 to the output for me...
    Nice tight fit...
    Got some water lines, a pump, and a heat exchanger mounted
    Packaged really nicely
    And got a prefilter for the dusty regions, this huge filter is a for a 7.3L Ford Diesel but it fits minty and is only $60
  13. Jul 12, 2023 at 8:42 PM
    #53
    vanhap
    vanhap Well-Known Member
    Steven
    CA
    97 Tacoma 4x4
    what a fantastic truck
    Speedytech7[OP] likes this.
  14. Jul 12, 2023 at 9:15 PM
    #54
    Speedytech7
  15. Jul 13, 2023 at 3:38 PM
    #55
    vanhap
    Steven
    CA
    97 Tacoma 4x4
    what CB are you/everyone using these days? I noticed you have a cobra 19 III right? is that all everyone uses, no high power stuff?
  16. Jul 13, 2023 at 3:41 PM
    #56
    Speedytech7
    I have the cobra 19 III, my buddies are using the same form factor uniden models (pro 520xl). But I'm getting ready to dump it for GMRS, tired of low distance and poor audio quality. They're just not worth keeping around for simple comms anymore I don't think. My buddies all have Kenwood HAM radios too, but I'm not convinced I need one really.
    vanhap[QUOTED] likes this.
  17. Jul 13, 2023 at 4:06 PM
    #57
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Meh I blew up my Kenwood. Prefer hand signals now.
    vanhap and 01x4 like this.
  18. Jul 14, 2023 at 7:28 PM
    #58
    vanhap
    Steven
    CA
    97 Tacoma 4x4
  19. Aug 21, 2023 at 6:04 AM
    #59
    Speedytech7
    Oops...
    Think I killed a shaft and seals on one front coilover and l most likely the seals on a rear one too, but not 100% on that. Time for rebuilds.
    Bandido, Digiratus and jubei like this.
  20. Aug 28, 2023 at 12:20 PM
    #60
    jamesgriff
    jamesgriff New Member
    james
    love this build!!!!
