another TSB question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfoster133, May 19, 2011.
  1. May 19, 2011 at 4:08 PM
    Bfoster133
    Bfoster133 [OP] If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    yet another tsb thread :eek:
    so im trying to get the tsb done on my tacoma, yes its eligible
    but they need it to bottom out before i can get it
    its bottomed out before with load, because we use it for work, i constantly have big pallets in the back but the drive from my work is kinda far to the dealership to be carrying a huge pallet that far.
    so my question is what is the minimum weight needed to make it bottom out over a bump, they will only do it if it does bottom out, i just dont want to carry a 3,000 lb in my bed for over an hour just so they can say "yep it needs it" then drive it allllll the way back to drop it off then back to the dealership to have it done, Thanks
  2. May 19, 2011 at 4:18 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I would question them on why they need it to bottom out. When I got mine done I just said it was 'harsh' going over speedbumps and they hooked me up. I know it doesn't answer your question but screw putting all that weight in the back just to prove they should fix something they already know they should fix.
  3. May 19, 2011 at 4:30 PM
    WCJR
    WCJR Well-Known Member
    W
    CALL CORPORATE AND COMPLAIN. YOUR DEALERSHIP IS AN ASSHOLE.
    I JUST MENTIONED THE TSB TO MY SERVICE PERSON AND REPLY WAS NO PROBLEM. MAKE AN APPOINTMENT.
    SOME OF THESE DEALERS ARE SCREWBALLS.
    COMPLAIN TO CORPORATE AND CONTACT THE BBB.
  4. May 19, 2011 at 4:35 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    For the record, "TSB" is a general term considering there are many different TSBs dealing with different issues. I wish my truck only had one TSB issued then I'd feel pretty great about my purchase.
    I believe some dealers interpret the following from the harsh ride TSB
    as a requirement that they need to test that the condition exists.
  5. May 19, 2011 at 4:41 PM
    Bfoster133
    Blake
    so can anyone give me maybe an aproxximant weight that would satisfy them?:confused::confused:
  6. May 19, 2011 at 5:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Tell the dealer to put a half dozen mechanics in the back and see how low it sits!
  7. May 19, 2011 at 5:48 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    I wouldn't just let the clowns off the hook.
    Ask for the general manager, explain what you have experienced, and that you are NOT willing to damage your truck further demonstrating it bottoming out. The TSB does not have a scientific way to assess load, so the dealer is bullshitting you. I have the TSB leaf spring upgrade and I can STILL bottom out the shocks. Anyway get the manager involved first, try to keep corporate out of it if you plan on using the dealership in the future.
  8. May 19, 2011 at 6:38 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    can you get a video with your phone next time you have it loaded at work?
  9. May 19, 2011 at 6:53 PM
    Bfoster133
    Blake
    i sure can, will probably be monday
  10. May 19, 2011 at 7:59 PM
    JKD
    JKD Well-Known Member
    Well, your payload capacity is around 1300 pounds. That's everything in the cab that isn't bolted down from the factory, including driver and passenger, plus everything in the bed. So if you weigh 200 pounds and carry nothing in the cab, then you can put about 1100 pounds in the bed and you will be at full capacity.
