Another turd gen can't engage 4WD
Discussion in 'Technical Chat' started by Trim taco, Aug 10, 2024.
  1. Aug 10, 2024 at 12:39 PM
    Trim taco
    Trim taco [OP] Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    I have a brand new, shiny, no-prize for anyone who can help with this:
    When i try to engage 4WD I can get into 4 HI just fine, but 4 LO will not engage. I recently swapped my front actuator tube for an FJ non-actuator tube and left a functioning front actuator plugged in. These 2 facts make me assume the problem is with the T-case actuator. The weird thing is, if I turn the dial to 4 LO it just flashes whether I try to move forward or reverse. But, if I turn off the engine, 4 LO is engaged when I restart. Also, I can't disengage 4 LO unless I turn off the engine again.
    My last offroad trip was about 4 months ago and, of course, everything worked fine then.
    Has anyone experienced this particular phenomenon?
  2. Aug 10, 2024 at 12:47 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Have you had this truck a while? 4 lo doesn’t shift unless clutch is held all the way to the floor. I know the manual says to be moving a few mph, but I have much better experience sitting still with clutch down. In fact, mine has never NOT shifted into LO when I was sitting still with the clutch down.
    ClassyTacos likes this.
  3. Aug 10, 2024 at 1:24 PM
    Trim taco
    I've owned the truck since new. I can't say that I had the clutch to the floor. I just tried to engage as I always have. But I'll give that a try an see what happens.
    Edit: I tried the clutch to the floor, not moving at all, and it engaged and disengaged like butter. I'll keep testing this as I have a trip in 4 weeks and I don't want to drive all the way to Colorado just to find out my 4WD doesn't work, again.
    Thanks for the tip.
    ClassyTacos and BLtheP[QUOTED] like this.
