Another UCA Question. (sorry)
Discussion in 'Suspension' started by cc tacoma, Dec 4, 2013.
  1. Dec 4, 2013 at 10:18 AM
    cc tacoma
    cc tacoma [OP] Member
    Cooper
    Prescott, Az.
    2009 Mag Grey Double Cab 4x4 Sport
    Hey everyone, I know that there are a ton of UCA threads but I couldn't seem to find the info that I was looking for. I have an '09 dbl cab 4wd. And I just ordered some new Icon 2.5 rr extended travel coilovers from SDHQ, and now I need to decide on a UCA and I'm torn between icon and total chaos. From what I have read, they both sound like they are high quality. The Icon has a uniball cover cap which I like, but the TC has zerks for greasing the pivots wich is also nice. Ultimately I'm looking for a low maintinece UCA and hopefully minimal squeaking. If anyone has any advice on this from past experience I would really appreciate it. Thanks.
  2. Dec 4, 2013 at 10:39 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
  3. Dec 4, 2013 at 1:30 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Any UCA that uses a uniball will squeek at some point. It's just the nature of the beast. All of the companies use stainless uniballs. If you use a dry teflon or dry film lube it will help.
    As for the bushings, the zerks are nice, again, proper upkeep goes a long way. Using the correct grease, not over torque'n them ect..
    The Cheaper arms out there are using lower quality material in their Uniballs and or Mis-alignment spacers. Those are the part's you need to hold up for the long run.
  4. Dec 4, 2013 at 3:25 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    My icons also have zerks for re greasing.
  5. Dec 4, 2013 at 3:31 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Fox Mid-Travel TRD Sport BSP 4x4 AC
    Fox 2.5 COs W/ TC UCAs + Fox 2.0 RR rears W/ Dakars, Brute Force Fab Sliders, BHLM, auto start, Redline hood struts, AVS bug deflector, thin lip satoshi, behing the grill 20in lightbar, cobra 29 CB, interior awesomness
    I like my TCs. They do squeak though. Whenever I get them plastered in mud the squeak comes back. I just hose them down and spray some triflow on the balls. Spray them down about once every two months and they are pretty quiet.
  6. Dec 4, 2013 at 3:32 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 35" Dynapro MT's
    Icon also has tubular UCA's that have zerkfittings.
  7. Dec 4, 2013 at 3:35 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Why no Camburg? They also have grease zerks.
    I love the fact that their UCA mounting hardware to the spindle is recessed into the top of the uni-ball.
  8. Dec 4, 2013 at 8:22 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Camburg are great1 But with Camburg you really need 4.75" Backspace on the wheels to clear the bigger Uniball. Icon also uses the Lowpro hardware.
    Camburg Uses Aurora Uniball's. They do squeek a bit sooner than FK's. Every one has the benefits.
  9. Dec 4, 2013 at 9:33 PM
    cc tacoma
    Cooper
    Prescott, Az.
    Wow! Thanks for all of the great input. I didn't know any of that. I guess Camburgs just weren't really on my radar for whatever reason but I'll certainly give them a look as well as the others mentioned. Super helpful, thanks guys.:)
  10. Dec 5, 2013 at 1:23 AM
    chipnoreo
    Anna
    Alaska
    As I understand it, TC, camburg, and icon are all great choices with minor pros and cons to each. I really wanted TC. Why? I honestly couldn't tell you but i was dead set on getting a pair. I liked the name I guess?? They have worked great so far too :D
  11. Dec 5, 2013 at 10:34 AM
    SoCaltaco65
    Nope
    Neither my mid nor long travel do
  12. Dec 5, 2013 at 8:21 PM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    With our uniball cover cap, that is a pretty big deal to help keep grit & grime from piling up in the uniball cup, you can't see it anyway! :D
  13. Dec 6, 2013 at 8:56 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    I agree with some of the above..
    Chaos uses 4130 tubing, a stainless bearing with 17-4 miss alignment spacers.
    Camburg uses 4130 tubing, a 1.25 Aurora bearing and stainless spacers
    Icon uses 1026 DOM tubing, a COM bearing that they have made for them in a stainless version (I believe?) and 17-4 stainless spacers
    All arms will add caster, all will squeak and most importantly all require maintenance from the end user.
    Clean the bearings and keep them free form debris, and when they start to make sounds use TRIFLO.
  14. Dec 6, 2013 at 9:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A large factor on the squeaking, make sure you rub grease all over the bushings when first installing. ALL over. Use rubber gloves. Then, a little grease thru the zerk every oil change would be fine.
  15. Dec 6, 2013 at 9:14 AM
    as well as the inside of the bushing and the out side of the sleeve.
  16. Dec 6, 2013 at 9:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo!
  17. Dec 6, 2013 at 9:17 AM
    08pretaco
    Oliver
    az
    Or just simply get the BJ style upper arms, I joke I joke
    Everyone hit all the important keys to trying to keep noise down.
  18. Dec 6, 2013 at 11:30 AM
    icon_rep
    Riverside, CA
    Since we are getting into details a little more, here is 2 other things we do....I attached a few example pictures.
    • Polyurethane bushings w/ anti-deflection ring
    • 17-4 Stainless Steel Uni-ball Adapter Taper Pin
  19. Dec 15, 2013 at 7:21 AM
    cc tacoma
    Cooper
    Prescott, Az.
    Wow!,
    Thanks for all of the info everyone. Super helpful, I really appreciate it. A lot of this stuff is fairly new territory for me :).
  20. Jan 4, 2014 at 7:26 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Did you choose your UCA yet? I am in the beginning stages of learning and want to add another question to your thread. Why should I get a uniball set up over arms that I can use a stock balljoint in?
