Another use for the Tacoma as a Dentist (Pic Heavy)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtdog, Jul 1, 2015.
  1. Jul 1, 2015 at 8:07 PM
    vtdog
    vtdog [OP] Well-Known Member
    NH
  2. Jul 1, 2015 at 10:06 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You hooked your grab hooks in wrong. The point of the hook does not go into a chain link, rather, the whole link should fit into the slot of the grab hook. Luckily, it appears as though you escaped any damage or injury because of it though.
  3. Jul 1, 2015 at 10:36 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Also prevents having to take a hammer to unjam the chain..
    Also be surprised with the amount of traction these trucks have the things they can pull!
    E-Paz 732NJ likes this.
  4. Jul 1, 2015 at 10:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  5. Jul 2, 2015 at 5:07 AM
    dcaplan
    dcaplan Well-Known Member
    Drew
    Fergus, ON
    2020 4Runner Venture
    I have done this with my truck a few times now, always works great!
  6. Jul 2, 2015 at 5:45 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    24 carat chain? :)
  7. Jul 2, 2015 at 6:02 AM
    Yota64
    Yota64 Professional Threadjacker
    How does the chain not slip through the grab hook when you don't secure it?
  8. Jul 2, 2015 at 6:10 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    The other links prevent it from sliding.
    DoorDing likes this.
  9. Jul 2, 2015 at 6:11 AM
    Sig45
    Mark
    Maine
    JINX!!!
  10. Jul 2, 2015 at 6:41 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have YET to bend a 3/8 chain with the Taco...however for heavy work like that I use the Military Power Wagon, when those pieces break, they are much easier to fix. However, that stump looks like it would have come out with a mattock. A high lift jack used as a come-a-long is also a very good technique and we don't risk expensive driveline bits and pieces. The HF 1 ton come-a-longs are good, single use tools and should be treated as disposable.
  11. Jul 2, 2015 at 7:32 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  12. Jul 2, 2015 at 8:49 AM
    hetkind
    Howard
    Johnson City
    I have tried the stump grinding routine with a rented grinder and found it to be a great success. When I built my shop, I brought in a D6 Dozer and a big 4x4 backhoe, and had giant bonfires for months trying to get the stumps to burn.
    Howard
  13. Jul 2, 2015 at 8:53 AM
    medic2230
    Murph
    Bama! Roll Tide
    Ballin yo!
  14. Jul 2, 2015 at 9:01 AM
    vtdog
    NH
    Thanks for the advice on stump pulling. I had never done it before so I guess I got lucky as had no problems. I did have to put the truck in 4wd/low to get traction. My son and I tried for over an hour to get out that stump with hand tools. It was an old YEW bush and they are known for deep tap roots. After pulling it out I saw that the stump simply separated from the roots and they remained in the ground. Luckily, there was enough of a hole to put in a new and different type of bush.
    I got the chain, hitch receiver, pin, and ball at wally world. The whole setup cost less than $ 40 and saved a ton of work. I will keep the setup in the truck for just in case when I go out on dirt logging roads in northern new england for fly fishing.
  15. Jul 2, 2015 at 9:07 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Leave the tree 6' tall, use a come along from top of trunk, mattock the roots out!
    Easy-peasy, down comes the tree!
  16. Jul 2, 2015 at 9:16 AM
    Old School
    I've taken a lot of trees down this way, and the root ball's gone when I'm done!
    Used to have a landscape business...
  17. Jul 2, 2015 at 9:30 AM
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
    yes like others said the chain goes into the grab hook. Make sure when you pull the chain straight it makes a straight line if not flip the hook.
  18. Jul 2, 2015 at 11:15 AM
    hetkind
    Howard
    Johnson City
    I like a 9 tined fork for chips, and you miss understand...once the stumps were dug out and piled up, it took a long time for them to dry out enough to burn in a bonfire...
  19. Jul 2, 2015 at 4:56 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Using a tow ball as a hook isn't a good idea.
    Gunshot-6A likes this.
  20. Jul 2, 2015 at 9:15 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    True. Better to use something like this.
    And toss another length of chain over your working chain to help prevent it coming back if it fails
