Another vibe thread...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1E7DCSB, Feb 16, 2018.
  1. Feb 16, 2018 at 7:47 PM
    1E7DCSB
    1E7DCSB [OP] Well-Known Member
    NH
    I didn’t want to revive zombie threads so I figured I’d make this one.
    My truck has vibes from 20-30mph while accelerating or decelerating, but goes away in neutral.
    I have a carrier bearing drop installed along with a new rear driveshaft, but the vibrations are still present through those speeds.
    It rattles the dash which drives me crazy and I’ve read about using axle shims, adding washers to the carrier drop, or just going with a 1 piece double cardan driveshaft.
    I’d just like opinions as to if I should get a new driveshaft made and installed, or if it’s worth the to time play around with shims and washers.
    The truck is a 2007 trd off road double cab with a 3” Bilstein 5100/ toytec lift with SPC uppers, AAL + block in the rear
    Thanks
  2. Feb 19, 2018 at 6:28 AM
    decoopa
    decoopa XPS-X MAN
    Knoxville, Briceville
    2014 Toyota Tacoma XSP-X
    Lifted with "Rough Country" kit, Blistien here I come.
  3. Mar 5, 2018 at 1:09 PM
    1E7DCSB
    NH
    I ended up getting a custom 1 piece shaft made today and it fixed every vibration my truck was experiencing. Extremely satisfied with the shop and result
