Another Vibration Thread with a Twist
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, Jul 17, 2021.
  1. Aug 19, 2021 at 6:26 AM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    Thanks all. Got a damper coming from a junk yard. Will see what happens.
  2. Aug 19, 2021 at 6:32 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    I had a very similar issue turned out the trans mount was toast, also 5 spd truck
  3. Aug 19, 2021 at 6:51 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Trans mount is good. Thanks.
  4. Sep 23, 2021 at 6:59 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Updating this. The diagnosis is that the pilot bearing failed (no noise heard by me) which in turn led to damage to the input shaft/bearings. So trans will be rebuilt. Having them put the Marlin Crawler shifter bushing in, even though I never had any issues there. New clutch, including resurfaced flywheel, shift fork, pilot bearing, T/O bearing, rear main seal. Truck is still in the shop. Supposed to be done before the weekend. Oh by the way, my T-case doesn't have holes to mount a dynamic damper so that was $65 wasted.
    Wulf and alarka like this.
