Another victim of temperature/compass meter damage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LASTCOWBOY, Apr 5, 2010.
  1. Apr 5, 2010 at 8:45 AM
    LASTCOWBOY
    LASTCOWBOY [OP] Member
    PUERTO RICO
    TACOMA TRD OFF ROAD SR5 2006
    Hi: I own a 2006 tacoma trd off road since december 26, 2009. This last saturday (april 39) the temperature/compass meter get totally off with no apparent reason. I think it can be a fuse but i read the manual, look in both fuses boxes and there is no fuse identification. I search in the web, until found this site. I will try removing the console and look if the 510 is unsolded. I will let you my luck.
  2. Apr 5, 2010 at 8:47 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Good luck with it
    And
    Welcome to TW
    :wave:
  3. Apr 5, 2010 at 8:48 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Good luck. April 39th huh? Wow, my calendar must be waaaay off.
  4. Apr 5, 2010 at 8:52 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    good luck...the writeup you're referring to did the trick for a lot of guys on here.
  5. Apr 7, 2010 at 4:33 PM
    jorgeocordero
    jorgeocordero Member
    07 Pre Runner TRD
    2nd, air filter removed,in cabin 110/ 400w mod.inverter.fog light any time mod.
    hello: Lastcowboy, I am new to the forum with the same problem on my tacoma 2007 trd & fixed. You have to open the sunglass compartment and remove the screw , then with your hands pull the front seccion close to the front glass down & foward its hard , have (3) clips. them losse the power wires and solther the (2) 510 resistorson the board behind the smoke palstic. am from puerto rico to. email me any dought at: jorgeocordero@gmail.com
  6. Apr 7, 2010 at 5:05 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    My temp gauge quit working so I took it apart. Looked like the solder was still there but added a blob anyway and temp gauge started working again.
