Another way to drain rear diff fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by slymedusa, Jan 16, 2024.
  1. Jan 16, 2024 at 3:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Smart.
    Now, find a Dremel or a chisel and beat the collar back in enough to get a socket on it.
    You're just asking for trouble using a wrench. Anything less than a 6-point and you're asking for more trouble.
  2. Jan 17, 2024 at 6:06 AM
    slymedusa
    slymedusa [OP] Complete Newbie
    Jorge
    Miami, FL
    2002 Silver Tacoma Prerunner
    I found a $40 rotary tool on Amazon last night, was able to get it for like $7 with some wizardry. Already got delivered this morning amazingly. Hopefully I'll have a positive update later today!
  3. Jan 17, 2024 at 7:40 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Take a flat head screw driver to that damaged area and hammer it out of the way. Loosen bolt. Nothing else to it.
    Steves104x4 likes this.
  4. Jan 17, 2024 at 6:27 PM
    slymedusa
    Jorge
    Miami, FL
    Appreciate all the advice! I was able to grind away some of the bent lip and get a socket around the bolt like many suggested.
    LarryDangerfield and Steves104x4 like this.
  5. Jan 18, 2024 at 6:29 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I would carefully file or grind away all of the bent lip. Then I would finish the job by cleaning the internal threads and install a new plug using a standard (i.e. not a deep-well), 1/2-inch, 6-point socket to fit. Lastly I would torque it to spec, and call it a day :curls:
  6. Jan 18, 2024 at 6:40 AM
    SHAKEnBLAKE
    SHAKEnBLAKE Well-Known Member
    Joe
    2007 DCSB Auto 4.0L
    Back-half, Dana 60, 4.56 spool, ARB front, Kings, sliders, etc.
    Glad to hear you got it figured out. Good for you for learning to work on your own stuff. Down the road you'll look at this and laugh that it was an easy challenge.
    slymedusa[QUOTED][OP] likes this.
  7. Jan 18, 2024 at 1:06 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Mine looks similar to this from off roading everytime I want to change my diff fluid.
    I use a dremel to remove the peened over bit of metal that's preventing a socket from getting in there.
    It takes less than a minute.
