Another Weird New Aroma...
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Sep 8, 2025 at 9:42 AM.
  1. Sep 8, 2025 at 9:42 AM
    skeezix
    skeezix [OP] Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    After driving 15 miles at 5-10 mph up a nasty, knarly, rock-strewn, half-washed-out dirt road to Wickiup Pass high up in the Henry mountains, I noticed a strange new aroma inside the cab like a combination of perfume and some kind of sweet, volatile antiseptic solution like one sometimes smells when inside a hospital or a doctor's exam room.
    The outside air temperature was in the mid-90s and a lot hotter under the hood.
    I got out and traced the smell to the smog stuff that's mounted under the hood on the driver inner fender, and I assumed it was due to the gas that I had topped the tank off with back in Hanksville (i.e. something in the gas). I shrugged my shoulders, got back into the cab, and continued crawling up the trail. The smell dissipated after a few more miles. WTF?? :notsure:
    Has anyone else here noticed odd smells coming from around the smog stuff when driving 5-10 mph under hot conditions?
    Black97v6MT likes this.
  2. Sep 8, 2025 at 10:16 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    2 off smells come to mind that may be what youre experiencing....
    nasty sulfar smell could be from the cat converter due to possible fuel trim issues, etc, bad cats, etc...
    your battery about implode....
    or, coolant leak so youre smelling coolant....
    ControlCar likes this.
  3. Sep 8, 2025 at 11:38 AM
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
    Were you using 4 wheel drive? T-case burping gear oil?
  4. Sep 8, 2025 at 5:10 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Coolant smells sweet
    check for dampness under dash on passenger side
  5. Sep 9, 2025 at 6:04 AM
    skeezix
    1998 Limited
    I was in FWD at the time and doing around 5-10 mph over a very rocky road. And the outside temperature was 90F+. The smell was like a sweet but somewhat pungent smell.
    No dampness anywhere in the engine compartment. The smell was coming from the emission fumes area and were strong there. It definitely was not the typical coolant smell. It's no big thing, I was just wondering if anybody else had noticed it.
  6. Sep 9, 2025 at 6:55 AM
    slater
    San Diego
    Could have been anything....
    Another good comment mentioned about.
    The smell of gear oil is very noticeable assign youre transfer case has gear oil & not ATF live fords...
    Look under the truck for any leaks.
    Transfer case, front differential axle seals, etc...
    Its a must, you have to look.
    Could save you lots of money in the long run if you find a leak & address it sooner than later.
  7. Sep 9, 2025 at 7:23 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Would this indicate a failing heater core?
    ControlCar[QUOTED] likes this.
  8. Sep 9, 2025 at 3:47 PM
    ControlCar
    Steven
    Sugar Land TX
    Maybe but OP has no dampness in cabin on pass side^^^^
  9. Sep 10, 2025 at 7:01 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Thanks, also wondering. I have had a different smell come up too, almost like a new shoe smell.
    But no dampness on the passenger side floor boards.
  10. Sep 10, 2025 at 3:28 PM
    ControlCar
    Steven
    Sugar Land TX
    For this ‘come and go’ smellness
    almost every manufacturer has air fresh air intake(s) for HVAC under wipers (the louvred cowl panel cover.
    im guessing that is where the smells are getting into cabin. Pulled in by squirrel motor. Much depends on if vehicle moving slow or at stop.
    for example, ever young and lit up your tires up and that burnt clutch smell hits you and then goes away?
    Source is tranny, then wafts its way to cowl inlet and you smell
    With tht being said
    -sweet coolant smell, source could be near rear of engine where CTS is or seeping heater hose connection
    -musty smell might just be an accumulation of leaves/debris under the wipers and cowl cover
    -new shoe(chemical?)smell……if not constant just could be ambient/outside(?)
    Regardless
    I would take wipers/cowl cover off, inspect and clean
