Another wheel and tire newbie question
Discussion in '1st Gen. Tacomas (1995-2004)' started by airbornm3, Mar 2, 2014.
  1. Mar 2, 2014 at 9:07 AM
    airbornm3
    airbornm3 [OP] Member
    Chicago
    01 sr5
    None
    Hi,
    FYI - I have googled and searched the threads on wheels and tires with a lift but need a little clarification on fitment and rubbing
    Im putting on a 3" OME lift with dakar leaf springs in back I want to fit one of the following combination:
    1. 15 x 8 Method double standards with 3.5 backspacing and 33x12.5 bfg mud terrains
    2. 15 x 8 wheelers steel wheels with 4 or 4.5 backspacing and 33 x 12.5 bfg mud terrains
    Will both fit?
    Or what other caliper clearing 15 x 8 rim will fit with 33 x 12.5 tires, what backspacing do I need? Any suggested combinations? Thanks and sorry to bug everyone with another mundane question.
  2. Mar 2, 2014 at 10:12 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Yes both options will work just fine. You will probably still need to do some trimming on the pinch welds and plastic in the front fenders.
  3. Mar 2, 2014 at 10:24 AM
    airbornm3
    Chicago
    01 sr5
    None
    604YOTA,
    Thanks for the reply, do you think the 15" Method Double Standards will clear the front calipers? I have a 2001 tacoma 4x4
  4. Mar 2, 2014 at 11:38 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    They should 1st gen tacos came with 15" wheels and 16"s shouldn't be a problem.
  5. Mar 2, 2014 at 11:41 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    In my opinion I would go with the wheelers steel rims if you plan to do any kind of offroading..my truck came with moot metals hate them.going to switch to steelies when I get a chance
  6. Mar 2, 2014 at 11:54 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    You may want to go to a tire shop and see if you can try the methods on before you buy them. 15's fit but some need a .25" spacer to clear the caliper. If you were to get 15" Toyota wheels then you shouldn't have an issue but aftermarket wheels are usually the ones that the caliper. It has to do with the hub mount, the Toyota ones protrude more so they wont rub the calipers and the aftermarket ones don't protrude enough, hence the .25" spacer needed. If you want to take the safe route get the wheelers wheels because they make those wheels to fit 1st gens and clear the calipers.
    As for the tire rubbing, you may have a little rubbage on the frame at full lock. Also, you can always hammer down the pinch weld if the tires rubs on it. Since your wanting the 12.5" wide tires your gonna have to trim more than if you were to go with a 10.5" tire.
