Another Wheel Bearing shot @65K :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd taco guy, Jan 11, 2011.
  1. Jan 11, 2011 at 8:16 PM
    trd taco guy
    trd taco guy [OP] Well-Known Member
    Rob
    09 tacoma trd sport
    So I Posted a thread a few weeks ago that i was a bit surprised that I had the driver rear wheel bearing go at 62K miles. Well sure enough 3K miles later the passenger rear went. Luckily it was covered by the power train warranty and they gave me a rental but only after alot of dealer BS of course. They ended up giving me a 2011 access cab sport which was nice cause it is the same truck as mine minus the color. the truck only had like 160 miles on it i noticed that they are still sending tacos out with the three leaf rear springs otherwise not too many differences from my 09. Not too sure if i like the new grill or not.
    I hope i dont have to deal with many of these issues with my truck once the 100,000 mile powertrain runs out i mean its not cheap to replace a wheel bearing from what i hear its around 600 bones per axle so im gonna keep an eye on the front ones when i get close in mileage
  2. Jan 11, 2011 at 11:28 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    think it was more of an engineering thing vs leaf count thing. I don't have a problem with my springs. I've yet to have one anyway.
    Wheel bearings at 60k... hm.. Low lube? That's not horrible, but pretty early most of the time. Seen plenty around 50-80. Seems to go in hand with poor tire maintenance, balancing or alignment or water crossing, clay etc. Anecdotally.
    No wheel spacers or anything?
    600 bones an axle, you ought to get out your hand cleaner and do your own, save yourself 500 of that if the bearings are REALLY freaking expensive. EDIT: which they dont seem to be unless you buy them with carrier.
    They're a maintenance item really. I've replaced dozens on cars under 100k that I've personally owned and diagnosed at least twice that. Others seem to never go bad. Ive got bad front bearing on my bike... its only got 12k on it.
  3. Jan 11, 2011 at 11:42 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    My front passenger bearing is going out i got 69k, I got it ordered today at claremont toyota for $53 but im sure the labor will be more than that as it takes some time to disasemble the front end
  4. Jan 12, 2011 at 5:24 AM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    both of my fronts are in need of replacement. i have 68K on mine. so it seems like 60k is right arond when they go out.
  5. Jan 12, 2011 at 5:35 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    How do you know when they go bad?
  6. Jan 12, 2011 at 5:38 AM
    danteisme
    Vandergrift, PA
    you'll hear them/ feel them. sounds like i have mud tires on my truck when i get up to speed. if they are real bad, if you jack up the truck you can hear them when you spin the wheel, or feel it if you hold the coil spring while you spin the wheel.
  7. Jan 12, 2011 at 5:38 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Damn, I've only heard of wheel bearings going out on small diameter wheels at that kind of mileage. My wife's 98 4Runner has 196K and still running on the original wheel bearings.
  8. Jan 12, 2011 at 5:48 AM
    MAXTacoma
    Lexus GS 350
    ^thanks thats good to know. I have 75k and dont think I have a problem.
  9. Jan 12, 2011 at 6:24 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm at 88k and very apprehensive of this. Hate fucking pressed in sealed bearings for fronts. Why couldn't they just stick with regular ones? Don't answer, it's a money thang I know. I don't has spacers or do much muddin or water crossings since prerunner but they are pushin 75lbs a corner tire/wheel combo and have a lot of 70mph frwy miles on them. Seem to be OK for now. Powertrain won't cover fronts on mine due to being prerunner I'm guessing. Hoping the rears shit the bed before 100k if they're going to.
  10. Jan 12, 2011 at 6:52 AM
    danteisme
    Vandergrift, PA
    when i do mine, i plan on removing the whole assembly, taking them to the garage and have them press the bearings and replace the seals, then jsut bring them back home and install them in the truck.. it seems like most of the labor is just removing all the crap to get to them, not the actual bearing's replacement. i'll just throw the removed parts on the motorcycle lol
  11. Jan 12, 2011 at 7:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    +2 on the DIY but why couldn't they just be like normal where you could service them with fresh grease on occassion taking about 30 min out of your life and be done and have them last much much longer was what I was getting at. I have no problem bustin out the wrenches and gettin dirty. The concept of building shit nowadays where it has to be brought to shop because of the hassle for the avg consumer instead of building shit to last just sucks. Wastes people's time that are still willing to get dirty with it....and more expensive for shittier parts too.
  12. Jan 12, 2011 at 7:35 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    do the extended warranties cover these?
  13. Jan 12, 2011 at 7:49 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its money, and convenience. I bet most people would not be able to repack bearing nowadays anyway. Look people go to jiffy lube for oil changes so bearing re-packing is out of the questions. My son is going to get driver license soon and I refuse to get him a car until he can do all the simple maintenance on it. His claim, nobody he knows in school does that anyway so according to him I am being unreasonable. He want s to be like others and just go to service. :rolleyes:
  14. Jan 12, 2011 at 9:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    03 regular cab 4x4
    I had to replace both fronts on my last 05 at 76k. The 05 I just bought needed both fronts (one was really, really bad) at 113k. And those were original. I think the big problem with the tacoma bearings is the inner seal. The inner side of the bearing is not sealed. If you take the plastic insert out of them the back side inner race is loose. The inner seal for the bearing that goes into the back of the spindle is actually a greased seal that rides on the CV shaft. The outer seal is just a dust seal. On 3 of the 4 front bearings I have changed this seal is shredded. According to my local dealer these very rarely get changed when they swap bearings. So I can imagine if the seal is gone new bearings won't last long.
    My wife has a 00 4Runner with 205k on it now. I just did both front bearings on it last month and now one of the rears is making noise. So you may be due soon. Changing out the fronts is no big deal on the older style or 05-up style if you have a press. I'm not looking forward to doing the rear on the 4 Runner though. It's got 2 spacer sleeves and an ABS ring pressed onto the axle that even Toyota says have to be cut off to change the bearing. That's going to be fun.
  15. Jan 12, 2011 at 10:04 AM
    phoneguy44
    phoneguy44 Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    hmm, just hit 60k on my 06.
    Is changing these barrings out a huge job ? We got any instructions out there letting us keyboard typers how to change them out ? Just curious.
  16. Jan 12, 2011 at 10:11 AM
    danteisme
    Vandergrift, PA
    beyond turning some wrenches i think you just need a large press to press the bearings.
  17. Jan 12, 2011 at 10:17 AM
    85GT 79FJ40
    Ken
    New Hampshire
    03 regular cab 4x4
    I've done all of mine with a made in china $129 12 ton press I bought from Jegs. If you do a search for wheel bearing replacement there are plenty of threads for the fronts. I know I've explained how it's done a couple times over the last month. Rears are a bit of a different story. You have to press the axleshaft out of the bearing. From what i've seen in the FSM this requires a special tool that bolts onto the outer axle end to secure it in a press. I'm going to make my own out of a spare axle housing I have when I do it on the 4Runner.
  18. Jan 12, 2011 at 11:10 PM
    island808
    Jedediah
    hawaii
    You can't really narrow it down to wheel bearings with a drive. But you can probably figure out what corner it is. If its bad enough to hear usually if you grab the top of the tire and yank back and forth. Squat down and bounce it back and forth.. you can feel a clunk. in trucks since they're so heavy, maybe take off the wheel and try to wobble the hub on the front.
    pretty much have to take off the drum to diag the back easily.
    Of course sometimes bad is tight. Hot hub is a sign. Touch (or shoot with IR therm) after driving. But that can also be a hung brake. Good tool to take to a used car drive. Ir thermometer. Can shoot exhaust manifold to check for bad combustion and brakes and hubs to check for cold or hot brakes.
  19. Jan 13, 2011 at 3:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It would not be unreasonable to take the position of get a job and then go buy your own shit, pay for the ins & pay for your own service. Bet he'd like that.
  20. Jan 14, 2011 at 12:07 AM
    island808
    Jedediah
    hawaii
    He can also ride the bus. I won't get into the stupidifying of urban america. I will say, my 6 year old has been changing oil for 2 years and begs to do it., has cried when I did it without telling him. I used to have to loosen the filter and pan nut.. but I did it before he gets under there so he thinks he did it. My 10 year old doesn't care to do it, but doesn't complain either. If its a choice of gapping plugs or cleaning room. Its gapping plugs and washing K&N, checking tire pressures. Funny though, I don't let them wash the cars. Though I do let my 10 year old shift gears if he's up front. Just don't let a 5 year old try to carry the full oil pan.
    Do bearings get "packed" these days. Its been a while since I've seen a maintainable bearing. Regardless, I only repack if its due to removing for the sake of say, a brake disk, never purely for maintenance purposes. A packable bearing is usually only a few dollars.
