Another Wheel Spacer Question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bearch, Jan 21, 2015.
  1. Jan 21, 2015 at 8:12 AM
    Bearch
    Bearch [OP] Well-Known Member
    Mat
    Vancouver
    '06 TRD OR SWB
    Hey guys,
    Been lurking around on here forever and thought I'd finally post something haha.
    Been reading alot about wheel spacers and from what I understand, you want a 6x5.5 hubcentric spacer with a 106 inside diameter. If you got 108 you'll need a centering ring and be wary of anything off Ebay.
    Now, I've found these:
    http://www.ebay.ca/itm/2pc-TOYOTA-F...yota|Model:Tacoma&hash=item23483e6b96&vxp=mtr
    Price is right, I messaged the seller who says they are 106 to 106 ID and there made of 6061 T6 Billet aluminum, CNC machined yada yada.
    I know if anyone posts anything on here, it will likely read something like "stick with spidertrax" but I wanted to go a bit wider than that. I'll be running stock Tacoma rims and I don't think 1.25" will be enough to get the stance I want.
    Does anyone have any input on these spacers before I buy a set? I've heard nothing but bad from people who've never run ebay spacers, and nothing but good from people who have which makes me wonder if it's just people being over-cautious.
    Hope to hear from you guys!
  2. Jan 21, 2015 at 8:14 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Jan 21, 2015 at 8:17 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
  4. Jan 21, 2015 at 8:27 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    FIFY
    I have the 1.25" spidertrax. I would not trust anything on Ebay since if it brakes..you WILL crash.
  5. Jan 21, 2015 at 8:30 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    OP was asking specifically 1.5" spacers. I have 1.5" spidertax wheel spacers. They just are not hub centric on the wheel side but, on the hub side they are.
  6. Jan 21, 2015 at 8:32 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have spydertrax and Im happy. I wouldnt go cheap on wheel spacers.
  7. Jan 21, 2015 at 8:33 AM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Ah, my apologies.
  8. Jan 21, 2015 at 8:40 AM
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    Has anyone on the forum ever had one fail? Just curious. All I would need is one failure and I wouldn`t think twice haha.
  9. Jan 21, 2015 at 8:48 AM
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    RadTaco914,
    Have you ever had any of the issues with vibrations etc? Also, will the acorn lug nuts they give you work with the flat face that the stock rims have?
  10. Jan 21, 2015 at 8:50 AM
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    Ive been running ebay spacers on multiple vehicles for years and never had a problem. When they cost half as much as other brands like spidertrax, its hard not to try out the ebay stuff. I have purchased and ran at least 4 sets of 1.5" or 2" spacers on ebay, and I will continue running them until I have a problem one day.
    Im sure there are people who have had them fail, but most of the time those failures are caused by improper installation. Surfaces NEED be clean before mounting, Locktite HAS be used, and they also NEED to be torqued properly. So many people have problems with any brand of wheel spacers because they did not install them properly.
  11. Jan 21, 2015 at 9:07 AM
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    This is exactly what I have heard before - the ones who have had ebay spacers have never had issues and love 'em, and those who have never run them say they're terrible.
    This is killing me... haha
  12. Jan 21, 2015 at 9:08 AM
    geekhouse23
    well-known brand name >>>> eBay
  13. Jan 21, 2015 at 9:19 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    well something to be said about the spidertrax. think you'll ever talk to the owner of the business of the ebay ones?
  14. Jan 21, 2015 at 10:07 AM
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    That is nice about spidertrax.
    Where are the ebay spacers likely to fail? The lugs or the spacer itself?
    I wonder because the spacer itself is the same material machined the same way so it will be more or less identical. My only concern would be the lug itself but even those are rated based on strength and come from a third party manufacturing source I assume? So the only difference (other than the anodizing) that I can see would be the care taken in pressing the lug into the spacer.
    Everyone seems to have an opinion, but nobody seems to have any reason behind it :p
  15. Jan 21, 2015 at 10:23 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Yeah unfortunately I cannot say where there really would be any differences in strength or quality. I would imagine the most common failure point is the studs, and I don't see those ever breaking as long as they are tight. As soon as a lug nut on the spacer or one holding the spacer to the vehicle comes loose, that's when you will have problems, no matter what brand it is. The only real difference I can see is if the machining tolerances for the hubcentric on the ebay ones are not exact causing a vibration at high speeds. This may be less likely to happen with Spidertrax spacers.
  16. Jan 21, 2015 at 1:24 PM
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    Well... C4 you convinced me... Ordered a set off Ebay. If anyone is interested I can post pictures when they arrive.
  17. Jan 21, 2015 at 1:57 PM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    I ordered what was supposed to be hub centric 1.5" spacers off eBay as well... And they shook like a drunk fresh out of booze.
    Will never do that again. Spidertrax for me.. Or BORA.
  18. Jan 21, 2015 at 2:05 PM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Here's my truck with the spidertraxx. Have had them for around 60k and no issues.
  19. Jan 21, 2015 at 2:10 PM
    ONEBAR
    ONEBAR Well-Known Member
    Josh
    Englewood, CO
    08 White TRD OR
    Seems like you didn't give much time for input haha..
    But personally I'd never trust no name spacers. If I went cheaper than BORA or Spidertrax, Synergy sells some 1.5" for around 80 I think.
  20. Jan 21, 2015 at 2:10 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Love my spidertraxx, have had them on now for about 8k miles no problems. Only thing I didn't do that c4 recommends is clean the area before hand. Use the RED loctite on the lugs and torque them to 90lbs, drive 50-100 miles and retorque them at 85lbs, if they move at all then drive another 50-100 and try it again at 85lbs. Thats what spidertraxx recommends.
