Another wheel/tire question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lionfan, Jan 31, 2011.
  1. Jan 31, 2011 at 3:02 PM
    Lionfan
    Lionfan [OP] Well-Known Member
    Colorado
    03 ext cab trd black
    Billy 5100's with eibach 3"coils and custom built rear leafs, brush guard and lights, sprayed in bedliner, camo interior, camo decals, new sound system, wet okole's, 265/75/16 tires, fog light mod, rear locker mod, deck plate mod
    I know there have been alot of questions about this and yes I have done the search but want all 1st gen opinions on this. I am going to get a set of bilstein 5100's and set them at the highest setting with stock coils(my coils only have 70k on them so I figure they will be ok right?) and an aal for the rear. I got a set of american racing tactic's from a guy for $300 and they are 16x8 with +10mm offset. I was told that that is basically a 4" backspace. So I am having a hard time deciding on going with 265/75/16's or 285/75/16's. I dont really want to go with the 265's cuz I would like to have a bigger tire than that and wider too. How much rubbing/trimming will there be with 285's and this wheel. I do not want to have to trim or grind a bunch of stuff either. The tire Im looking at say on the specs that they are 33.2" tall and 11.4" wide. Post pics if ya got em too cuz I would like to see the difference between the 2 sizes. Thanks
  2. Jan 31, 2011 at 4:06 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    i'm still stock but i plan on putting some billies on and some eibach coils... i've heard that 285/75/16 will rub if you have only a 2.5 inch lift. so you'll probably have to trim a lot:(
  3. Jan 31, 2011 at 10:51 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    hammer and cutting, 285's should be fine.
  4. Feb 2, 2011 at 8:31 AM
    Lionfan
    Colorado
    Anybody? Not much info yet. How is it that some guys have no problems and others have to cut out a bunch?
  5. Feb 2, 2011 at 9:58 AM
    R.etheridge
    R.etheridge Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    because of different tire companies. Say you have a 285/75 toyo open country and a 285/75 BFG At. these 2 tires will differ in size because they are made by two different companies. I have a true 3 inch lift, the same as what your putting up front plus I added a rev tec spacer to get a true three inches and I have 285/75/16 yoko geolanders on some 09 trd wheels with 1.25in spacers and I only rub at full lock pulling in and out of my driveway and I didnt cut, hammer, or bend anything. Im ditching the spacers as soon as I get the $$ up for some trd fj wheels.
  6. Feb 2, 2011 at 6:18 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Just hammer the shit that rubs... No cutting involved!
