Another Wheel/Tire Thread for 1" poke
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trl1990561, Aug 26, 2021.
  1. Aug 26, 2021 at 4:39 PM
    trl1990561
    trl1990561 [OP] Well-Known Member
    Tyler
    Jupiter, FL
    2021 Lunar Rock Tacoma TRD Pro
    Prinsu Rack, 265/70/R17 KO2,RRW R7-H RCI Rock Sliders,RCI 18" Bed Rack, Decked System,Baja 40" Amber Roof Light bar, Baja Amber Ditch Lights,Baja Amber Fogs, ARB Twin Compressor, Switch Pro, Blaze Offroad Wiring
    Looking to buy RRW-7H wheels but not sure on the offset to get. I'm looking to run 275/70/R17 but mostly looking for a wider stance. I have a 2021 TRD Pro and not looking to cut or relocate. What offset/tire size to go with ? They are offered in -12 or -25 offset.
    Lets see those pics/specs
  2. Aug 26, 2021 at 4:46 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    -12 is your best bet. The more offset, the more cutting. Not sure you can get away with more than 265/70/17 without cutting and -12 might make that a problem
  3. Aug 26, 2021 at 4:50 PM
    trl1990561
    Tyler
    Jupiter, FL
    Do you know if this size would give me a 1" poke or a little wider stance?
  4. Aug 26, 2021 at 5:03 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    12mm is 1/2". Anything over 265 is a gamble on having to cut. Width is the cause of rubbing ftmp
  5. Aug 26, 2021 at 5:23 PM
    trl1990561
    Tyler
    Jupiter, FL
    Ok so a 265/70/R17 with a -12 offset will give me the closed look im looking for without the need to cut/relocate?
  6. Aug 26, 2021 at 5:24 PM
    Wyckedan
    Dan
    Woodinville WA
    No promises, but that would be a safe bet
  7. Aug 26, 2021 at 6:36 PM
    AODRN
    STL
    You will at least have to remove mud flaps
