Another Wheel/TPMS Question...
Discussion in 'Wheels & Tires' started by wdmccall, Mar 14, 2012.
  1. Mar 14, 2012 at 2:53 PM
    wdmccall
    wdmccall [OP] New Member
    Dale
    SC
    2011 Tacoma 4x4
    New guy here. I did search the forum, but I didn't see an answer to my question. Thanks in advance for any help you guys might provide. I have a 2011 tacoma with the steel wheels. Of course I am wanting to change to Toyota alloys. Part number for the wheel I am looking at is 42611-AD031. I know I will have to buy new tpms sensors for these alloy wheels. My question is, do I buy the ones specific to this wheel, or do I buy the ones for a 2011 tacoma? Will the ECU read either? Also, do you guys have any part numbers for the ones you would recommend, including the fitment kits? Again, thanks for your help...
    Dale
  2. Mar 14, 2012 at 4:25 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    You can take the ones out of your stock wheels and re sell them without tpms's ....or you can buy new TPMS's ..probably from the place u r buying the new wheels. TPMS's are programmable once installed you will need to go to a local shop that has the equipment to program them to your truck...usually about $50 bucks. I bought my wheel and tire set up with new TPMS's from discount tire direct....took me a while to find a shop that had the right equipment...if u can keep your old ones I would recommend that...new sensors run about 60 -70 bucks a piece....hope it helps
  3. Mar 14, 2012 at 4:55 PM
    wdmccall
    Dale
    SC
    2011 Tacoma 4x4
    I know the sensors from the steel wheels won't work with the alloy wheels. But should I be looking for sensors specific to the alloy wheel, or to the year of the truck?
    Thanks,
    Dale
  4. Mar 14, 2012 at 5:05 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    When I bought mine from discount tire...they asked me year, make and model...so go with that. I went from trd wheels to xd addicts. Try and get them from the same place u get the wheels.
