anothernord's JDM 1KZ-TE diesel swap (2001 Tacoma 3.4)
Discussion in '1st Gen. Tacomas (1995-2004)' started by anothernord, Nov 11, 2016.
  1. Nov 11, 2016 at 2:19 PM
    anothernord
    anothernord [OP] Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    I've always thought it would be cool to have a small displacement diesel in my truck. So I decided to do it.
    Diesel Toys charges $20,000 for a conversion. Screw that. I'll do it myself for a less.
    I found a 1KZ-TE from a Japanese importer from a KZN185 (Hilux Surf, or 3rd Gen 4Runner) and had it shipped to CO. If you're looking for a diesel to swap into a 1st gen taco or 3rd gen runner, this is the one to find. It already has the correct oil pan and engine mounts to go into a 3.4 powered 4wd rig. The wiring harness has to be extended about 30", so I'm in the process of that as well as doing some miscellaneous wiring for things such as the glow plugs relay, fuel heater relay, and spill valve relay.
    Specs on the engine:
    1KZ-TE from 1996-2000 Hilux Surf (KZN185)
    145 hp, 253 ft-lb @ 2000 RPM (should be easy to crank it up to 170 hp and 300 ft-lbs
    SOHC, timing belt
    Indirect injection, electronically controlled plunger-style injection pump
    (Ignore my Subaru in background)
    I got right to work tearing into the harness and labeling everything in an excel spreadsheet as well as good ol' masking tape.
    Motor gettin' turnt (down).
    Upon disassembly of the motor, I found sadness. A glow plug tip had broken off and played around in the cylinder, scoring the walls and damaging a piston. Off to the machine shop and eBay UK to source new oversized pistons and rings!
    Here's the fuel filter assembly I'll be using. It's from some Duramax and features a built-in, thermostatically controlled heater, and water-in-fuel warning switch. Just gotta find a spot in the engine bay.
    I'm going to pick up the block from the machine shop in the next few days, and will begin the rebuild of the motor. Stay tuned y'all.
    Edit: here's some videos from the end of the project:
  2. Nov 11, 2016 at 2:30 PM
    Xyphon112
    Xyphon112 Well-Known Member
    Awesome. I'm very interested in how this plays out. Do you have any idea how the diesel compares in reliability to the 5VZ and what the gas mileage is?
  3. Nov 11, 2016 at 2:34 PM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    These a pretty bulletproof engines, from the same family of engines as the 2L-T in the Top Gear Hilux. The older-style heads sometimes crack due to overheating, but mine looks to be one of the updated designs.
    Gas mileage will be better, as you'd expect. I can get up to 21 on the highway with my turbo'd 5VZ, so just looking at the difference in energy density of the diesel fuel, plus the higher compression ratio and some tuning, I should be getting around 26-27 pretty easily. (edit: I get about 23 city/25 highway, but I imagine that will get better as the engine breaks in)
  4. Nov 11, 2016 at 2:36 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Holy shit. this is awsome. :popcorn:
  5. Nov 11, 2016 at 3:56 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
  6. Nov 11, 2016 at 4:00 PM
    Large
    Large Red
    Nice .. I love these builds
  7. Nov 11, 2016 at 4:13 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sign me up.
  8. Nov 11, 2016 at 4:59 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Awesome! Been interested in trying this myself one of these days. Subd for how it turns out
  9. Nov 11, 2016 at 6:34 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    :cheers::militarypress::jerkoff: subd ive always wanted to see this happen
  10. Nov 11, 2016 at 7:04 PM
    Xyphon112
    So cool. How much did the engine cost? Are you planning on doing a write-up on the wiring situation?
  11. Nov 11, 2016 at 7:09 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Sub'd for some Toyota diesel action :goingcrazy:
  12. Nov 12, 2016 at 8:26 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    At it again you crazy sum'bich? Love your work man, very cool stuff. You going to turbo the shit out of it or what? I've always been intrigued by the idea of a small diesel running like 50 psi of boost in a Tacoma.
  13. Nov 12, 2016 at 9:34 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Sign me up.
    Can you go into detail on the specs. What size turbo, how do you crank it up? Piggyback programmer? What does the power band look like?
  14. Nov 12, 2016 at 10:48 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    :popcorn:Sub'd
    Love my Tacoma but would absolutely never get rid of it ever if it was diesel
    suzuguru likes this.
  15. Nov 12, 2016 at 11:12 AM
    Gaunt596
    Matthew
    Central Maryland
    I'm also guessing that, because you have the ECU,this will pass OBD2 Emissions checks?
  16. Nov 12, 2016 at 11:17 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    :sandwich:Subbed for this! Shit's gonna be sic
  17. Nov 12, 2016 at 12:36 PM
    r45d
    r45d Well-Known Member
    Georgia
    01 DC 4WD
    This site never fails to amaze me. I am shocked at the engineering people pull off in their garage on a weekly basis.
    Willbeck likes this.
  18. Nov 12, 2016 at 1:28 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
  19. Nov 12, 2016 at 1:41 PM
    Workaholic
    Workaholic Well-Known Member
    Simi Valley CA
    97 Tacoma 4x4
    You selling that turbod 3.4??:boink:
    Tucker771 likes this.
  20. Nov 12, 2016 at 1:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bad. Ass.
    Manfred and Jimbotron like this.
