anothernord's JDM 1KZ-TE diesel swap (2001 Tacoma 3.4)
Discussion in '1st Gen. Tacomas (1995-2004)' started by anothernord, Nov 11, 2016.
  1. Dec 14, 2016 at 1:29 PM
    #81
    anothernord
    anothernord [OP] Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Last night, I plugged in everything and made sure none of the electrical smoke got out. So far, everything electric works perfectly. 4WD, starter relays, reverse lights, glow plug relay, fuel heater relay, dash lights, all work as they should.
    I found a relay box from a 95 camry for $12 on eBay and used the two relays inside as the glow plug and fuel heater relay. It's mounted next to the main fuse box.
    Here's a better look at the duramax fuel filter bracket I made. There's room to run the CAT filter and adapter that someone suggested. I'll run it as-is for now. It uses one of the old charcoal canister mounts and one of the brake booster nuts to mount.
    I also sketched up a CAD file for the dump-pipe flange, and sent the file to a local water jet shop. I'll be making a full 3" exhaust to go along with it.
    Transmission crossmember being relocated. Lots and lots of grinding.
    Sorry for the cell-phone pictures. I'll post more from my DSLR.
    #81
    suzuguru, nfs257, Torspd and 5 others like this.
  2. Dec 14, 2016 at 2:36 PM
    #82
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Awesome work man... If only Toyota had made them from the factory!
  3. Dec 14, 2016 at 2:42 PM
    #83
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Thank you! They did make them from the factory... just not in this country. :sad:
    This is honestly a pretty straightforward swap other than the fuel system and some of the wiring. Lots of things are compatible with the Tacoma's chassis. For example, the auto shifter linkage and t-case shifters line up perfectly in all the original connection points.
    suzuguru likes this.
  4. Dec 14, 2016 at 2:44 PM
    #84
    E30325
    Nick
    Did they really? I knew they had made trucks and 4runners with diesels in the past for the non US market, but I didn't know there was ever a foreign market diesel Tacoma
  5. Dec 14, 2016 at 2:46 PM
    #85
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    This is a tag. Awesome work
  6. Dec 14, 2016 at 9:20 PM
    #86
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    a lot of south america/africa and europe diesel is cheaper than gas and easier to find
    Torspd likes this.
  7. Dec 15, 2016 at 9:01 AM
    #87
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    I see em all the time here in So Cal with Baja plates, they're called the Toyota Hilux for the non US market.
  8. Dec 15, 2016 at 9:09 AM
    #88
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    :drool: Yea this is right up my alley I love the Toyota diesels. Amazing job doing what few have the balls or the knowhow to do
    Including myself :anonymous:
    Spintly likes this.
  9. Dec 15, 2016 at 1:52 PM
    #89
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
  10. Dec 15, 2016 at 2:19 PM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  11. Dec 18, 2016 at 9:49 PM
    #91
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Started up the first try, even in -5 degree temps. Pictures and videos to come.
  12. Dec 19, 2016 at 1:40 AM
    #92
    Gaunt596
    Matthew
    Central Maryland
    :goingcrazy:
    WildLand likes this.
  13. Dec 19, 2016 at 10:11 AM
    #93
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    :dancingbacon::broccoli::bananadance::kona::taco:
  14. Dec 19, 2016 at 10:29 AM
    #94
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    awesome!
  15. Dec 20, 2016 at 12:13 AM
    #95
    E30325
    Nick
    Video of it rolling coal...? :headbang:
    COMAtized99 likes this.
  16. Dec 20, 2016 at 6:52 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Dec 20, 2016 at 8:45 AM
    #97
    Gaunt596
    Matthew
    Central Maryland
  18. Dec 20, 2016 at 10:15 AM
    #98
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For me > :redxfall:
  19. Dec 20, 2016 at 12:59 PM
    #99
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    You guys are a riot.
    It's not quite on the road yet, there's still the front end to put on and the interior to put back together. I was gone all weekend too.
    My DSLR wouldn't do any video since the metering is broken, but here's a video to prove that it runs! I promise I'll put up better, longer videos later.
    This was taken right after it started up. I let it run till it warmed up fully, at which point it was idling happily.
    (sorry it's not very long video)
    https://youtu.be/O73FHP7TQvc
    I had a little Cheech and Chong action going on while it warmed up for the first time and burned off all the oil from assembly:
    Other things:
    I had a local driveshaft shop extend the front and shorten the rear by 6.5". It turned out that the rear shaft should have been more like 6.75", but everything still works fine. For anyone looking at doing this, I'd just measure first since each truck could be a little different.
    I shortened the gigantic starter cable to reach nicely to the stock battery location (I will do a dual setup sometime)
    For the radiator hoses, I used 2 Gates part numbers: 22495 for the upper and 21706 for the lower. I basically just went to O'reilly's and grabbed a few I thought would work and picked these 2. I also used part of the stock upper hose for the 1KZ's upper hose.
    The lower just required 2 cuts and a splice using a 1.5" to 1.5" barb fitting, and for the upper, I cut and rolled beads in a 1.5" piece of aluminum tube.
    Lower hose before cutting and installing:
    Rolling beads:
    Upper hose installed:
    KIMG0328_30ac1df2008b6de4204ff6488c79035106fe32be.jpg+
    Better view of fuel filter bracket when installed:
    **The reason I'm using the stock intercooler is just to get it running. I'll add the FMIC later**
    suzuguru, joshipps, boostedka and 4 others like this.
  20. Dec 20, 2016 at 1:02 PM
    #100
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Perfect time to make a custom scooped hood.
