antenna help needed
Discussion in 'Audio & Video' started by mudduck, Mar 3, 2009.
  1. Mar 3, 2009 at 10:58 AM
    mudduck
    mudduck [OP] Nobody makes me bleed my own blood.
    the bluegrass state
    09 TRD Sport
    black painted wheels, tinted windows, sockmonkey decals
    a few months ago, i installed a shorty antenna. it looks great, however i lost a lot of signal strength. to remedy this problem, i bought an antenna booster. it looks simple enough to install...Simply plug booster into radio and antenna into booster. Connect power lead to switched 12-volt power source and your done. my question to you guys is, where would be the best 12-volt power source? thanks for your help in advance!
  2. Mar 3, 2009 at 11:17 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    You could probably just splice it into the radio power supply ( red and black wires usually) but double check to make sure. Also make sure that it has its own fuse and if you splice it into the radio, see if you can do so BEFORE the radio's fuse so it won't potentially get overloaded even though I can't imagine that the booster requires much power.
  3. Mar 3, 2009 at 11:22 AM
    mudduck
    the bluegrass state
    09 TRD Sport
    thanks for the help. here's the booster i picked up. http://www.jcwhitney.com/autoparts/..._ID:2001196&productId=2001196&catalogId=10114
    i figured for ten bucks its worth a shot.
  4. Mar 3, 2009 at 11:23 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Is the radio power supply line switched?
  5. Mar 3, 2009 at 11:29 AM
    mudduck
    the bluegrass state
    09 TRD Sport
    i have no idea. i've got an 09 with jbl option. does the ignition count as a switch for the radio?
  6. Mar 3, 2009 at 11:31 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm just thinking of external amps. They have an always on power supply, but they have a remote wire that turns the amps on/off.
    I don't know if the radios turn on/off based on the power line or a remote wire.
  7. Mar 3, 2009 at 1:55 PM
    TightShirts
    TightShirts The StormTrooper
    TightShirts
    Phoenix... The Land of Lifted Trucks & Dirty Sluts
    08 Rugged Trail Ed
    Tint, Clear Bra, De-badged, In-Dash DVD, 09 Led Tail Lights, Chris4x4's old OME front shocks, 1.5" Deaver AAL with OME n182s, black billet in white sport grill, BHLM w/4500k HIDs + Fogs, bumper blackout
    you could splice it into the 12v cig outlet under the stereo or on the acc wire on the stereo... both are only powered when the key is turned.
  8. Mar 3, 2009 at 2:00 PM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
    Uless of course you modded the cig lighter. where's that damned dancing banana? The volt meter is your friend.
    There he is.
    :bananadance:
  9. Mar 3, 2009 at 2:03 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    what mod are you doing that no longer uses a 12v wire to the outlet?!? :confused:
  10. Mar 3, 2009 at 2:06 PM
    Stu
    G'Ville, NV
    Taco TRD OR
    It's no longer "switched" 12 V.
    sorry for cornfusion.
  11. Mar 3, 2009 at 2:16 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    ok... that makes sense. there's been a time or two that i've wanted it not to be a switched source :p
  12. Mar 3, 2009 at 3:54 PM
    mudduck
    the bluegrass state
    09 TRD Sport
    do you know which wire is the acc wire?
  13. Mar 3, 2009 at 6:48 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    According to these wiring diagrams it looks like it's going to be a solid grey wire that's on the plug for the stereo. It is the same color for both JBL and Non-JBL stereo systems.
    If you have an aftermarket stereo it will be a red wire. All aftermarket stereos have a standard color layout.
  14. Mar 4, 2009 at 8:53 AM
    mudduck
    the bluegrass state
    09 TRD Sport
    thanks for the help. i used the gray wire and things seem to be working well. for some reason though, my airbag light is now on. i guess i'm gonna unhook the battery and hope that it resets.
  15. Mar 4, 2009 at 9:00 AM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    not trying to be a smart ass but why dont you just get XM? i havnt used a fm radio station in 5 years and havnt looked back.
  16. Mar 4, 2009 at 9:10 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I don't like extra monthly bills.
  17. Mar 4, 2009 at 9:42 AM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    the airbag shouldn't have anything to do with that wire... let me know how the reset goes
  18. Mar 4, 2009 at 2:08 PM
    mudduck
    the bluegrass state
    09 TRD Sport
    yeah, i thought the exact same thing. funny thing is, when i got in this morning and fired her up, no air bag light. so i guessed it fixed itself. things are good to go.
  19. Mar 4, 2009 at 3:23 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    :woot:
  20. Mar 4, 2009 at 5:56 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    Hows the reception now? Noticeably better?
