antenna issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swwacoma, Nov 13, 2008.
  1. Nov 13, 2008 at 1:12 PM
    Swwacoma
    Swwacoma [OP] Doomsday Squad
    Estero, FL
    08 PreRunner SR5.
    You guys have problems with your antenna coming loose after extended drives on the interstate? I found after driving about 3 hours between 70-90 mph my antenna will become loose...Maybe one day it will fly off, that would be far more hilarious then annoying.
  2. Nov 13, 2008 at 1:16 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    torque it down a little bit, maybe put some loctite in there
  3. Nov 13, 2008 at 1:37 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you do use locktite, only use a tiny bit so you keep conductivity. But ya, about every month or so I go re-tighten it. I'm gunna pick up a stubby pretty soon so hopefully that won't back off as much. Lot to be said for the antenna's in rear windows these days...
  4. Nov 13, 2008 at 2:14 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Don't be afraid to get out the adjustable wrench. Mine had a tendency to loosen up because I tapped it going into the work garage. I used a wrench and it hasn't backed off yet.
  5. Nov 13, 2008 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  6. Nov 13, 2008 at 2:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    my 06 antenna got loose...dealer didnt tighten it down. i tightened it up and and never did come back loose. a little blue loctite will work, but only use a little.
  7. Nov 13, 2008 at 2:48 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I did with the OEM, multiple times. I now have a stubbie antenna and it hasn't budged.
  8. Nov 14, 2008 at 3:22 PM
    Swwacoma
    Estero, FL
    08 PreRunner SR5.
    Meh, I like your suggestions, but I think I'll just wait for it to fly off..you know, like I said it would be hilarious and give me a reason to get a stubby antenna.
