Antenna keeps screwing loose.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Feb 24, 2008.
  1. Feb 24, 2008 at 6:01 PM
    ERdept
    ERdept [OP] Well-Known Member
    So I have to tighten the antenna every couple weeks.
    What's the fix for it?
    Pliers and locktite?
  2. Feb 24, 2008 at 6:09 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  3. Feb 24, 2008 at 6:09 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    A bit of locktite will do the trick.
  4. Feb 24, 2008 at 6:11 PM
    GregO
    GregO Northern Alliance:Scout-sniper
    06 TRD/SR5-4WD Off RD pkg.
    2 JL-10's,1400watt Amp, IPOD interface, Maglite holster,
    Yah, I ran into this problem when I first got my taco, but all I did was take out a pair of pliers and wrench that mo fo down, didn't use locktite but it would probly be a good idea..
  5. Feb 25, 2008 at 12:02 AM
    ERdept
    OK. Since I don't want to mess with it again and think that I'll never need it out, I'm going loctite red instead fo blue, and some padded vise grips.
  6. Feb 25, 2008 at 6:51 AM
    argm31i
    argm31i Well-Known Member
    Locktite would probably work, but keep in mind that if you go through a car wash, they might try to unscrew it (or you might need to do it to prevent it getting bent over/off).
  7. Feb 25, 2008 at 7:29 AM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    A small rubber O ring that just fits over the threads will do the trick also. When the antenna is tightened, the O ring will hold pressure against it and keep it from turning. Also makes it easier to remove if needed than with Locktite.
  8. Feb 25, 2008 at 7:29 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Don't do loctite. Just tighten the crap out of it. I'd be worried that the loctite will affect your radio signal. If you do loctite, don't do it over all the threads.
  9. Feb 25, 2008 at 3:32 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    A little blue Loctite won't hurt.
    To get it tight without scraping up your antenna, put a small rubber hose over the antenna and then grip that hose near the base with a pair of pliers and tighten the antenna. The rubber hose will grip the antenna tight enough to tighten it, but it won't grip it so much that you strip out the threads or snap off the stud.
  10. Feb 25, 2008 at 4:00 PM
    txtoy
    txtoy Member
    08 PreRunner TRD Off Road Double Cab Short Bed
    So is your antenna just coming loose on its own, or is it from banging it on the top of the garage door going in and out? I just got a shorter antenna.
  11. Feb 25, 2008 at 6:08 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^I would imagine on it's own: vibration from flapping in the wind. That's how mine came loose. I also replaced mine but just for looks. I went with a black shortie antenna.
    Just wanted to add, it doesn't affect my reception at all. I did just what you say, though, a small dab on one side.
  12. Feb 26, 2008 at 4:35 AM
    ERdept
    OK, fixed it good.
    It was coming loose on its own, from just road jarring. I don't and haven't knocked it on anything.
    I also will not remove it for car washes.
    I wash at home.
    Reception is as always, normal.
    Went with red Locktite and padded vise grips.
    Thanks all.
  13. Feb 26, 2008 at 5:35 AM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Good tip. Mine is always coming loose as well.
  14. May 20, 2010 at 11:05 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Just a bump for this thread for those that aren't aware. My '10 is only a month old and I was getting the rims switched out last night. I was poking around while I waited and just happened to feel the antenna. Imagine my surprise when the thing was so loose it was about to fall off!
    I tightened it finger tight, and will be applying a more permanent fix from those suggested above very soon.
  15. May 20, 2010 at 12:08 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Our 09 does it as well.
    They take it off at the car wash but it doesnt seem to take long to get loose.
  16. May 20, 2010 at 12:27 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The O ring is a great idea.
    You can also use a small lock washer.
    A wrench will fit, no need to chew it up with pliers or vice grips.
  17. May 20, 2010 at 1:39 PM
    06stex
    06stex Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    i just used some teflon tape and 2 yrs troublefree and it never has given me any radio signal issues.
  18. May 20, 2010 at 2:20 PM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    x100
    used just a tad of loctite on just part of the threads.
  19. May 20, 2010 at 2:25 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Oh My God Toyota needs to tell the Govt. and have a RECALL
  20. May 20, 2010 at 2:57 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
    2 years and it hasn't come loose
