Antenna / Light / Whatever bed mounts from ATO!!
Discussion in 'Armor Tech Offroad' started by Fire931, Dec 19, 2010.
  1. Jan 3, 2012 at 10:01 PM
    #41
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Good question. Because i am still interested
  2. Jan 5, 2012 at 9:47 AM
    #42
    Joeymgd78
    Joeymgd78 Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
  3. Jan 6, 2012 at 10:06 AM
    #43
    ponq
    ponq Active Member
    me three
  4. Jan 6, 2012 at 10:13 AM
    #44
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    We are, we have just been sold out for a bit now. I'm getting more made up but they will be done after I get all the group buy pieces taken care of so it will be a few weeks. Thanks
  5. Jan 12, 2012 at 1:08 AM
    #45
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Is the bed rail grounded ? This will make mounting a cb antenna so much easier if it is.
    thanks
  6. Jan 13, 2012 at 7:52 AM
    #46
    Fire931
    VA
    00 4Runner
    No I don't believe it is, however we do provide a spot for mounting a group strap to. :thumbsup:
  7. Jan 13, 2012 at 12:50 PM
    #47
    Mitch
    Mitch
    Spokane, WA
    Any chance of running a GB on these? I bet we could get a good amount of people to jump on board
  8. Jan 13, 2012 at 2:39 PM
    #48
    Rellik01
    Craig
    Windermere, Florida
    Could you elaborate on the ground strap, if you clear this up for me I am ready to pull the trigger and order 2.
  9. Jan 13, 2012 at 2:58 PM
    #49
    Mitch
    Mitch
    Spokane, WA
    As am I
  10. Jan 13, 2012 at 3:05 PM
    #50
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    The track system is not grounded so anything you mount to it will likewise not be grounded. For instance if you mounted a CB antennae you would need to ground it meaning running a wire from the mount/antennae to a solid ground. It's nothing you wouldn't do regardless of what type of mount you purchased.
  11. Jan 13, 2012 at 7:34 PM
    #51
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    I'm going to preface this with I'm new to CB's but learning alot.
    I just picked up an antenna today from a local guy that sells CB / Ham radio stuff out of his house (and online) he sold me on an Everhardt No Ground antenna. Talking to him about properly grounding the rail in our composite beds was going to be a lot more work than it sounds. From what he said these no ground antennas are great and were specifically designed for fiberglass vehicles i.e. boats & motor homes.
    This is his website if you have any questions give him a call. Also I don’t see the antenna I got from him on his site, I may have gotten the last one. It was $36.95 and came with cable and a mount which I will upgrade when ATO has these mounts ready to go . Also when mounting I used some of the extra bed rail nuts I bought from ATO awhile back, these things are GREAT for mounting stuff to our rails.
    http://www.commproducts.net/category-s/76.htm
  12. Jan 14, 2012 at 5:42 AM
    #52
    Fire931
    VA
    00 4Runner
    Well the brackets have two holes which are for mounting the bracket to the bed rails, then we have a 3rd hole inbetween them which is tapped out for a small bolt. This gives you an easy spot to attach a ring terminal which is connected to a ground wire which you can run wherever you choose.
  13. Jan 14, 2012 at 6:17 AM
    #53
    Kangonia
    Kangonia I'm proficient with both chainsaw and shotgun...
    Eric
    Greenville, SC
    Project Storm Trooper
    Wheels / Tires / DeBadged / Anytime Fog Light / Color-Matched Satoshi (HomerTaco) / WeatherTech Floor liners/ Rear Leaf TSB/ Illegal Tint
    Sub'd for next batch
  14. Jan 14, 2012 at 1:26 PM
    #54
    Rellik01
    Craig
    Windermere, Florida
    polease tell me how to proceed to order two antenna mounts. Paypal, info.
    Thanks
    Craig
  15. Jan 15, 2012 at 9:06 AM
    #55
    Fire931
    VA
    00 4Runner
    I'm waiting on the next batch to come in right now. I'll post up when they are available and we can go from there. Thanks
  16. Jan 15, 2012 at 9:24 AM
    #56
    Mitch
    Mitch
    Spokane, WA
    Dibs on 2 of them
  17. Jan 17, 2012 at 7:46 AM
    #57
    ponq
    ponq Active Member
    can't wait for them
  18. Feb 2, 2012 at 10:40 AM
    #58
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    I'd be interested in a group buy as well. If not, still interested :D
    Fire, how big is the hole on the mounts? About how much (if you had to guess) weight could these bad boys hold?
  19. Feb 13, 2012 at 2:25 PM
    #59
    Mitch
    Mitch
    Spokane, WA
    Kevin,
    Any updates?
  20. Feb 13, 2012 at 2:30 PM
    #60
    jandrews
    '09 FourDubDee TRD OR
    I would be down on a couple of these as well...group buy would be welcome gravy :D
